287
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. L1611781032288
    Cupcake Apr 19, 2021
  2. PapaMac
    PapaMac , via OnePlus 7T , Apr 19, 2021 :
    I have a new, factory unlocked 7T that I purchased from a 3rd party. I am on the T-Mobile network. I don't know if my OxygenOS 11 update is supposed to come from OnePlus, or from T-Mobile. Both updates are being pushed, but for some reason, I'm still stuck on OxygenOS 10. Any ideas as to why? I can't even manually push the update. It continues to say that I have the latest version
  3. vuttamb
    Eclair Apr 19, 2021
    vuttamb , Apr 19, 2021 :
    Abort, Don't upgrade wifi disconnection issues still exists on 11.0.0.2 for 2.4Ghz networks. 5Ghz is stable tho..
    Too early to tell about the camera issue and frame drop.
  4. Le_hoonigan
  5. Sam197
    Jelly Bean Apr 19, 2021
    Sam197 , via OnePlus 7T , Apr 19, 2021 :
    Go to OB1 thread,flash the downgrade link that will take you back to OS10 beta
    Then update your phone to the latest OS10 stable,and wait for the notification.
    If you can't wait,use oxygen updater,go to settings and switch to advance,when they start to release the update in your region you ll get the notification
    tomsbautista, tsar777 and Aaron2017 like this.
  6. Sam197
    If your phone unlocked you should get the update from OnePlus,it doesn't matter which network you are using.
    Aaron2017 likes this.
  7. saravanakumarkn
    Gingerbread Apr 19, 2021
  8. PapaMac
    Thanks. That's what I thought. I wonder why the hold up then
  9. Sam197
    OnePlus released the update in India for now,till this minute global and European versions are not released yet
  10. PapaMac
    Good to know. Thanks again
  11. Sam197
  12. carljr07
  13. sambit1+
    Froyo Apr 19, 2021
  14. utkarsh_14
  15. sudamSreenath
    Donut Apr 19, 2021
  16. JIBINS
    Froyo Apr 19, 2021
  17. JIBINS
    Froyo Apr 19, 2021
