287
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. SHREYASADSULE
    Eclair Apr 19, 2021
  2. Ayush_Jangta
    Eclair Apr 19, 2021
  3. Sam197
    Jelly Bean Apr 19, 2021
    Sam197 , via OnePlus 7T , Apr 19, 2021 :
    Ask in 6 series threads,you are not in the right thread here
    ghostofcain and Aaron2017 like this.
  4. Aaron2017
    Lollipop Apr 19, 2021
    Aaron2017 , Apr 19, 2021 :
    Mate, most of us don't even know when we'll get this update, let alone the 6 series.
    ghostofcain and Sam197 like this.
  5. Ayush_Jangta
    Eclair Apr 19, 2021
    Ayush_Jangta , via OnePlus 7T , Apr 19, 2021 :
    After google rolling out android 12 and oneplus strating to develop oxygen OS 12 and make you realise you should have never settled for a Oneplus Device
  6. myilraj
    Cupcake Apr 19, 2021
  7. Harshit Singla
  8. Ayush_Jangta
    Eclair Apr 19, 2021
    Me waiting for my OXYGEN OS 11 OTA update, reading same comments here and realising OTA UPDATES roll out in patches and you literally can't do anything about it. Instead just wait. Sed Life . Hope they don't pull down 11.0.0.2. 🥺
  9. Sam197
    Do you think 6 hours SOT is not enough?
    Is it what you mean?
  10. sreyasvarier
    Froyo Apr 19, 2021
  11. Harshit Singla
    Harshit Singla , Apr 19, 2021 :
    It's 6 hrs on normal.usage....if I m using it extensively then it lasts for max 3 hrs...
  12. Sam197
    Are you facing this issue since you got your phone or recently
  13. Harshit Singla
    from the starting.....I bought it in October 2020
  14. McLarenMania
    Honeycomb Apr 19, 2021
  15. Sam197
    Did you try to do factory reset?
    Look in apps section,try to find if any apps running in the background,you should get a warning but DIY
    Aaron2017 likes this.
  16. Harshit Singla
    ok will try
  17. Sam197
  18. Harshit Singla
    do factory reset will erase all of my data
  19. Sam197
    Yes so you better back up your data to you Google account.
    You can use OnePlus switch as well but save the data o your PC or laptop
