286
OxygenOS 11.0.0.2 for the OnePlus 7T Pro and OnePlus 7T
  1. Aaron2017
    Lollipop Apr 16, 2021
    Aaron2017 , Apr 16, 2021 :
    Like the original post says, staged roll-out, only a limited amount of users get it now, the rest later. Could be weeks or more before everyone gets it.
    AzureB1te, _krishu_1017 and Sam197 like this.
  2. Sam197
    Jelly Bean Apr 16, 2021
    Aaron2017 likes this.
  3. _krishu_1017
    Cupcake Apr 16, 2021
    _krishu_1017 , via OnePlus 7T , Apr 16, 2021 :
    Okki .. thank uu
  4. Astr0niK
    Astr0niK , Apr 16, 2021 :
    Guys, what about battery on this update? I'm stayed at 10 and haven't idea about 11. I've heard complaints about the shelf, a few more standard applications. And battery complaint. Inform me, plz.
    underground1, babijoee and AzureB1te like this.
  5. HarshaKasi7
    Gingerbread Apr 16, 2021
    AzureB1te likes this.
  6. Praveen723
    Praveen723 , via OnePlus 7T , Apr 16, 2021 :
    please update about wifi disconnection issue, camera crash issue and frame drop issue if u can.. that will be helpful.
    most importantly battery drain issue.
    if these are fixed then i will be switching to this build otherwise i am happy with oos 10.
  7. C1595357182772
    Donut Apr 16, 2021
    C1595357182772 , via OnePlus 7T , Apr 16, 2021 :
    I have updated it and it works like charm now. Looks like OnePlus has fixed the issues with previous version.
    But I still find one annyoing issue with me where my wifi keeps reconnecting after few minutes of interval. Anybody else facing this issue, this is seriously a big bug.
  8. Praveen723
    what about frame drops. do u play pubg? if yes, how is the game play now? and wifi disconnection is major issue, is it fixed really?
  9. AndroidManiac
    Honeycomb Apr 16, 2021
  10. S1596736678495
  11. PriyeshPatil
    PriyeshPatil , via OnePlus 7T , Apr 16, 2021 :
    Thanks 👍🏻😊
  12. V1616350648526 , via OnePlus 7T Pro , Apr 16, 2021 :
    Was waiting for an update to fix wi-fi issue. If this doesn't fix, there is no point to update. Somehow the workaround (using only 2.4 GHz band) is working and stable. Don't want to mess that up again.
    PriyeshPatil likes this.
  13. rohankumardutta
  14. dipakagarwal17
  15. AndroidManiac
  16. PriyeshPatil
    I played both pubg and fortnite mobile... Pubg has it's own issues actually ! Although I did not see any frame drop but the game server is unstable now due to ban in India ! I did not notice any WiFi disconnect as you mentioned ! Fortnite Mobile makes your phone very HOT now in this update ! ( Note : I've being playing fortnite mobile on this device since launch ) Hence I did not bother to play Pubg with 90fps after that as it will be too hot to handle for sure !
  17. akbarmanjappara
  18. Praveen723
    i have been playing pubgm on 90 fps with os 10 since the day it came and it doesn't heat that much.
    But when i switched to os 11 beta 1, phone heated like an iron and battery backup was low (around 1.5-2 hrs less than os10).
    that's why i rolled back to os 10 stable.
    But seeing many people complained about wifi disconnecting and frame drops in os11 stable, i wanted to know if these are fixed.
    other issues don't bother me that much.
  19. Praveen723
    U are using 5ghz band or 2.4 ghz? i think people are facing disconnection issue with 5 ghz band..
  20. musucool
    Eclair Apr 16, 2021
    J1584964050378 likes this.
