193
OxygenOS 11.0.1.1 for the OnePlus 7 Pro and OnePlus 7
  1. sahil sonii
    Froyo May 31, 2021
    Tobi 97, T1570024183543 and Naarshan like this.
  2. TxGopi
    Honeycomb May 31, 2021
    dgnbrk likes this.
  3. Adi_2019
    Ice Cream Sandwich May 31, 2021
    Adi_2019 , via OnePlus 7 , May 31, 2021 :
    Yes of course. It will downgrade directly from 11 to 9, but it will wipe your phone. So take backup of all media files, call logs & sms.
  4. TxGopi
    TxGopi , via OnePlus 7 Pro , May 31, 2021 :
    Fully clear format?
  5. Grangeos
    Cupcake May 31, 2021
  6. Adi_2019
    Yes. It will erase your phone completely. It will be like the first time you switched your phone on after purchasing it.
    (It's better to remove google account and lock pin/password/pattern in phone before installing this OS).
  7. TxGopi
    Google account remove then password remove ?
    tell this link which version Android 9.5.0 or 9.5.1?
  8. Adi_2019
    Remove google account from settings>accounts>google
    Then install that version. It will install 9.5.1
  9. TxGopi
    Ok 9.5.1 perfect work ?
  10. Adi_2019
    9.5.1 is about 2 yrs old version. Phone will work perfectly but there are some features which came later so those will be absent. So, it depends upon your preference.
  11. TxGopi
    Ok thanks bro
  12. dgnbrk
    Froyo May 31, 2021
    Sanket_Shivgan likes this.
  13. mrmatrix
    Froyo May 31, 2021
  14. manishbaghla
    Donut May 31, 2021
    manishbaghla , via OnePlus 7 , May 31, 2021 :
    They just drop a message to you and don't look after that....this is so disgusting... it's irritating when you are not able to pick the phone and had to wait for 10 seconds to receive the call... please provide the solution asap...🙏🙏
    Tobi 97 and bcharles99 like this.
  15. snakesam
    Gingerbread May 31, 2021
    Grangeos likes this.
  16. V1599308922454
  17. Amey93
    Froyo May 31, 2021
  18. HansPety
  19. Singhnaman
    chiragvadhavana, GeekyNik and Sach716 like this.
  20. sahil mendiratta , via OnePlus 7 Pro , May 31, 2021 :
    It's slightly on the right side
