193
OxygenOS 11.0.1.1 for the OnePlus 7 Pro and OnePlus 7
  1. jatin0990
    Gingerbread Jun 4, 2021
    jatin0990 , via OnePlus 7 , Jun 4, 2021 :
    When update is available
    DMaarten likes this.
  2. D1566310177432
    Eclair Jun 4, 2021
  3. Singhnaman
  4. X1562868597718
    Cupcake Jun 4, 2021
    Kashishakul likes this.
  5. M1595166102518
    Cupcake Jun 4, 2021
  6. O1569093906893
    Donut Jun 4, 2021
    O1569093906893 , via OnePlus 7 , Jun 4, 2021 :
    Why my phone is vibrating without any notification after the update?
    Battery Drained very fast and heating also when charging..
    Please fix the issue..
    wifi not connect automatically when enter in to wifi zone you have to do manually every time..
  7. Loubear likes this.
  8. DMaarten
    Honeycomb Jun 4, 2021
    DMaarten , Jun 4, 2021 :
    People, you can use Oxygen Updater from thr Google Playstore to grab thia latest update if the OTA hasn't come through yet for you
  9. avik331
    avik331 , via OnePlus 7 , Jun 4, 2021 :
    Ok so I have realised this that, I m in India n I have installed the global version of the ROM, will there be any issue there?
  10. karim.Fadel
  11. U1604472686617
    U1604472686617 , Jun 4, 2021 :
    The global version seems to be the one with the most issues going by the complaints in all the threads.
    I used Oxygen Updater and installed the EU version and the only issues so far for me are.
    The stock camera app is playing up by being slow to start and the video recording not working reliably.
    I am using 3rd party camera apps which work fine both for pictures and video recording.
    The system sounds and haptic response being very quiet.
    Otherwise all else is fine.
    No overheating or excessive battery drain.
  12. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Jun 5, 2021
    Artemus , Jun 5, 2021 :
    I'm on global and I'm not getting any problems.
  13. U1604472686617
    Gingerbread Jun 5, 2021
    U1604472686617 , Jun 5, 2021 :
    None at all??
    Even the camera issues described by me above?
    The low volume system sounds and the very quiet haptic sounds?
  14. emeraldgameshark , via OnePlus 7 Pro , Jun 5, 2021 :
    They can always add AOD and let users have the option to switch it ON or OFF. Why are they making it so difficult. Battery drain is not the issue here. BBK is behaving like Apple atleast Apple admitted it. It's called "Planned Obsolescence" they want us to buy their new models
    Kashishakul and Adg123456789 like this.
  15. Artemus
    Mmm, nope. Everything works just fine for me. It might be device-specific.
  16. E1619303458124 , via OnePlus 7 Pro T-Mobile , Jun 5, 2021 :
    Ever since the past 2 updates, the 90hz option on my OnePlus 7 pro has been working for a little while, then the frame rate drops significantly. I don't have a lot of storage or ram used on the phone, I have it cleaned every week, and yet the frame rate still drops insanely. It has gotten to the point to where the 60hz option is just as good as the 90hz, and the show fps dev tool does nothing but print which setting you have selected. Please fix.
    S1581808983383 likes this.
  17. U1604472686617
    Mine is a GM 1910.
    What's yours...
  18. en_v_de
    Eclair Jun 5, 2021
