193
OxygenOS 11.0.1.1 for the OnePlus 7 Pro and OnePlus 7
  1. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Jun 6, 2021
  2. Ganesh S Malani
    Donut Jun 6, 2021
  3. D1597033750856
    Cupcake Jun 6, 2021
  4. D1597033750856
    Cupcake Jun 6, 2021
  5. D1597033750856
    Cupcake Jun 6, 2021
  6. prad1382
    Gingerbread Jun 6, 2021
    prad1382 , via OnePlus 7 Pro , Jun 6, 2021 :
    There should be an option to install update i.e. Global version , which seems less buggy than the so called local or country specific version, in this case the Indian version seems to be having lot of issues with Android 11.
    L1574835032431 likes this.
  7. Aubfred08
    Cupcake Jun 6, 2021
    Aubfred08 , via OnePlus 7 , Jun 6, 2021 :
    There are things the stable version took out that are making other apps to not work properly
    My duplicates file remover app can search and identify duplicates but then crashes when it wants to delete duplicates. Yet when was on beta 4 could use the app properly.
  8. U1604472686617
    U1604472686617 , Jun 6, 2021 :
    I would reply but the community app does not load on OOS11...:///
  9. WAQUAR_ALAM
    Froyo Jun 6, 2021
  10. Artemus
  11. U1604472686617
    Finally loaded and I sent in the required info about the stock camera app,,,
    Also sent in another report about the low volume on system sounds and very faint haptic vibrations...
  12. L1574835032431
    Cupcake Jun 6, 2021
    L1574835032431 , via OnePlus 7 , Jun 6, 2021 :
    This update doesn't work oneplus. I didn't had any issues with my phone when i first got oxygenos 11 update(or didn't noticed it ). But when updated to oxygenos 11.0.1.1 the phone got worst all the things it was suppose fix started happening. ONEPLUS PLEASE FIX THIS.
  13. Artemus
    Artemus , Jun 6, 2021 :
    When did you last wipe your phone?
  14. Krishna Prithvi
    Eclair Jun 6, 2021
    Krishna Prithvi , via OnePlus 7 , Jun 6, 2021 :
    After the latest update, battery life has been drastically decreased. On previous build I used to get from 5:30-7hrs sot. Now on latest update, I'm only getting 5-5:30hrs sot for the same usage pattern
  15. ihteshamraza
    Cupcake Jun 6, 2021
  16. Ankita_S.
    OnePlus Bug Hunter Staff Member Jun 6, 2021
    Ankita_S. , Jun 6, 2021 :
    For analyzing this better we would need more details & to get this sorted out at the earliest, We've dropped you a personal message and would request you to respond to the same.
    Regards,
    Ankita
  17. Artemus
  18. ihteshamraza
    Cupcake Jun 6, 2021
    ihteshamraza , via OnePlus 7 Pro , Jun 6, 2021 :
    Wow, it doesn't make any sense coming from Oneplus. My selfie camera hasn't been working since a week now and all they told me was to reset the phone. Not even sure if OTA worked for someone else
  19. Artemus
    This isn't the beta thread, btw. So.
  20. karim.Fadel
    srdic.tihomir likes this.
