193
OxygenOS 11.0.1.1 for the OnePlus 7 Pro and OnePlus 7
  1. Artemus.
    Community Hero 2020 Aug 2, 2021
    Artemus. , Aug 2, 2021 :
    That might be why. It's an issue with global OOS on T-Mobile-branded 7 Pro, not the T-Mo firmware. You're safe.
  2. ra1016 , via OnePlus 7 Pro T-Mobile , Aug 2, 2021 :
    Thanks. As long as my phone is working as smoothly as it is and is doing everything exactly the way it is supposed to (kudos to the T-Mobile Android 11 version update), I'm not all that concerned with the why.
  3. Medullitus
    Froyo Aug 2, 2021
  4. Medullitus
    Froyo Aug 2, 2021
    Medullitus , via OnePlus 7 Pro , Aug 2, 2021 :
    My experience is great MashaAllah, alhamdulillah
  5. Medullitus
    Froyo Aug 2, 2021
    It seems like an hardware issue mate
  6. Medullitus
    Froyo Aug 2, 2021
    It's late but better late than never. Absolutely right!
  7. Medullitus
    Froyo Aug 2, 2021
    No there can be more or less it's up to decision of the company
  8. Medullitus
    Froyo Aug 2, 2021
    U1604472686617 likes this.
  9. Medullitus
    Froyo Aug 2, 2021
  10. Medullitus
    Froyo Aug 2, 2021
  11. Medullitus
    Froyo Aug 2, 2021
  12. Medullitus
    Froyo Aug 2, 2021
  13. Buzz85
    Froyo Aug 2, 2021
    Buzz85 , via OnePlus 7 Pro 5G , Aug 2, 2021 :
    Every handset is supposed to get 2 major os updates.
    The 7 series had its first when upgraded to OS 10.
    My point was, the 7 series is further down the pecking order. You might get it, but you'll be waiting.
  14. Medullitus
    Froyo Aug 2, 2021
    It's supposed but it's not certain! This is what you can't get. I believe Oneplus will surprise us. Because I believe in this AMAZING company. But they need to convince Qualcomm too.
  15. that1matt
    Eclair Aug 2, 2021
    that1matt , Aug 2, 2021 :
    Found a solution for global OOS.
    For those with the GM1915, having the display resizing issues. Here is a potential fix.
    1. Set your display timeout to 30 mins.
    2. Set display resolution to QHD
    3. Turn off screen size switching
    4. Set refresh rate to 90Hz
    5. Enable developer options
    6. Connect to a computer with adb drivers
    7. Run adb shell settings put global oneplus_screen_refresh_rate 0
    This seems to be running pretty well for me, and haven't experienced the bug in a few days or so.
