193
OxygenOS 11.0.1.1 for the OnePlus 7 Pro and OnePlus 7
  1. HIMANSHU 1107
    Cupcake May 24, 2021
    nizamsyed786 likes this.
  2. gdsingh94
    Jelly Bean May 24, 2021
    gdsingh94 , via OnePlus 7 , May 24, 2021 :
    Thats something that whatsapp has done and nothing to do with oneplus..
  3. s.suri97
    Eclair May 24, 2021
    s.suri97 , via OnePlus 7 Pro , May 24, 2021 :
    Alas, not fixed!! They don't do anything they'll just ask for logs and even after a month.. the update is still crap.. overnight battery drain still 25% even with WiFi & Mobile data off. The bluetooth scanning under location accuracy setting still turns on automatically... Although WiFi n 4G stability seems to be improved.
    adi.muhic and nizamsyed786 like this.
  4. jatin0990
    Gingerbread May 24, 2021
  5. s.suri97
    Eclair May 24, 2021
    Totally agreed !! These people will just ask for logs and still after a month the new update is as BAD as the earlier one. Shame on OnePlus..
    Ash_Patil likes this.
  6. Nickers_iv
    Donut May 24, 2021
    Nickers_iv , via OnePlus 7 Pro , May 24, 2021 :
    Everything got better: the heat disappeared when using the device and when charging. 2. System response is faster. 3. The proximity sensor was repaired. But! The interface in the dialer has become small, why ?! Charge statistics are reset only to 100%, not 90. There are some nuances with auto brightness. The blue opening bar of the selfie camera is shifted to the right. Please correct this.
    GJM2, Shalin05 and nizamsyed786 like this.
  7. Raghava2706
    Honeycomb May 24, 2021
    Raghava2706 , via OnePlus 7 Pro , May 24, 2021 :
    Are u using whatsapp beta ? If so, uninstall and come back to stable.
    Even I faced this issue when I was on beta. I came out of beta and installed stable version. I got the pics back.
  8. Z1611427511162
    Z1611427511162 , via OnePlus 7 , May 24, 2021 :
    How to go to stable? Whenever I download , beta version is only downloaded
  9. Raghava2706
    Uninstall beta version completely. And install stable version. Before uninstalling check if there is option to come out of beta.
  10. ron_R
    Eclair May 24, 2021
    ron_R , via OnePlus 7 , May 24, 2021 :
    Updated yesterday and calibrated battery by charging till 100% and discharged till 15%. Now again charged at 100% and it seems to be working fine.
    This update seems to be responsive than previous one. Also WiFi issue has been solved.
    Please note that i wiped cache and formatted phone after the update. Maybe thats why i am not facing any issue now.
    SebastianKNT and tausif1590 like this.
  11. gdsingh94
  12. Swapnil4776
    Eclair May 24, 2021
  13. gdsingh94
    You will get the update if you wait..
    Swapnil4776 likes this.
  14. isohaibkhan007
    MelvinAbes, Shalin05 and Vinod_cr7 like this.
  15. vjgeorge87
    vjgeorge87 , via OnePlus 7 Pro , May 24, 2021 :
    Default dialler app font size has been reduced after updating 11.0.1.1.
    The notification light of front camera has shifted right. This has been notified in the previous update as well.
    I am yet to find other bugs.
    Come on OP.. Are you guys sincerely obeying 3rd law of Newton!!
    Shalin05 and s.suri97 like this.
  16. Ajay_Bhatt
    Froyo May 24, 2021
    Ajay_Bhatt , via OnePlus 7 , May 24, 2021 :
    OnePlus stop playing mind games with the customers.
    Giving crippled upgrades so that the customers can move into your newly launched devices.
    Keep in mind. You're in the Headlines of technical world by giving these rubbish updates.
    You'd ended your game by yourself.
    R.I.P Oneplus. Its Settled.
    After this update Oxygen Os 11.0.1.1
    The device is still getting heated after a normal video call of 5 minutes.
    Battery is still draining as hell.
    Ram management is worst.
    Camera has no improvements either.
  17. Adi_2019
    Ice Cream Sandwich May 24, 2021
    Adi_2019 , May 24, 2021 :
    It might be a bug in pro version. In non pro OP7 dialer is normal. Screenshot_20210524-113816.jpg
  18. isohaibkhan007
    isohaibkhan007 , via OnePlus 7 Pro , May 24, 2021 :
    Yes it's true...Well said brother
    ajay_nr likes this.
  19. s.suri97
    Eclair May 24, 2021
    Agreed bro.. Literally their OS doesn't want to settle..
    Same issues on my 7Pro.
    They just ask to submit a bug report with logs and what they give back to us is a crappy update again.
  20. Shiva_Rohith
