193
OxygenOS 11.0.1.1 for the OnePlus 7 Pro and OnePlus 7
  1. Merliin
    Cupcake May 24, 2021
  2. ajay_nr likes this.
  3. Z1611427511162
    Z1611427511162 , via OnePlus 7 , May 24, 2021 :
    Thanks , issue resolved
  4. Raghava2706
    Honeycomb May 24, 2021
  5. [email protected]
  6. Shekhar_29
    Shekhar_29 , via OnePlus 7 , May 24, 2021 :
    After updated OS 11.0.0.2 on my one plus 7.. got hanging problem day to day and also process slow.. still 105 GV free of my memory, why like this I don't no.. if you are not rectify the problem.. Im not like one plus and in future change to Apple.. see the picture first time I writing comments and post time only processing only show.. later I switch of my phone and again do now.
  7. rwmchan
    Jelly Bean May 24, 2021
  8. Raghava2706
    H1561476019849 likes this.
  9. DeependraAddo,B
    Donut May 24, 2021
    DeependraAddo,B , May 24, 2021 :
    please can someone confirm of the refresh rate and the screen flicking issues has been fixed on this new update 11.0.1.1. because i can't still use my phone on 90hz, and resolution QHD+ . I have set the refresh rate to 60hz and resolution to FHD+ Before I can use my 7pro.which for me I see them to be a big issue OnePlus need to fix ASAP. for now I have rolled back to Android 10.3.8. holding on to hear OnePlus has fixed the 90hz refresh rate and the QHD+resolution issues on the 7pro. before I will upgrade to Android 11.
  10. DeependraAddo,B
    Donut May 24, 2021
  11. Raghava2706
    Raghava2706 , via OnePlus 7 Pro , May 24, 2021 :
    Have u cleared cache? If not, please do and check. If the issue still persists reset to factory. Make sure you take a backup of your data.
  12. Shekhar_29
    First time I cleared cache done.. again after 2-3 days it's occur.. how it's problen of OS.. ? If need to reset means 100 GB over need to backup ?
  13. Raghava2706
    Sometimes it is recommended to hard reset ur mobile. Even if u talk to customer care they ask u to reset. If the data is important then u have to take a backup. If u have paid to google drive for 100gb then take a backup in that.
    check if 100gb of data is important.
  14. nosvasedis
    Gingerbread May 24, 2021
    nosvasedis , May 24, 2021 :
    This waiting for the EU version of the SAME update is really starting to get on my nerves.... Come on, they should just release it at the SAME time for all variants!
    Shinjuurou and Bierten77 like this.
  15. Dk1621
    Sagarshaikh and anujthakurece like this.
  16. Shalin05
    Shalin05 , via OnePlus 7 Pro , May 24, 2021 :
    Its an incremental roll-out so once the users who have recieved it receives the update and confirm about the things are working fine, then only we will start getting update!!!
    Hopefully we expect the things are fine & the build is stable enough as its a hugh update.
  17. sonukr7
    Eclair May 24, 2021
    sonukr7 , via OnePlus 7 , May 24, 2021 :
    Hey OnePlus please tell me what should I do....my OnePlus 7 is heating like hell and battery backup is also very bad after android 11.0.0.2. Should I go for battery replacement or this update will fix this. So Please standby with your brand reputation and inform me what should I do as my hand cannot bear this much heat and pathetic battery issue on a daily basis.
    Thanks.
    T1570024183543 and ABINASH_PANDA like this.
  18. Melkuse Daniel
    Ice Cream Sandwich May 24, 2021
    Melkuse Daniel , via OnePlus 7 Pro Nebula Blue , May 24, 2021 :
    For me the device is too good when compared to previous update, as most of the problems has been fixed, I personally faced the heating issue even on normal usage without gaming and while charging, low notification volume issue, but after update the issue has been resolved.
    But in previous update the call of duty used to crash and frame drops here and there, but now its happening most of the times I don't know whether it's app problem or os as the frequent app crash is happening only after the cod recent update ( only cod other apps are running fine).
    Still the os need to be optimised for gaming may be only for cod other games are running fine no issues.
    But for battery backup good compared to previous update but it's too soon to judge, need to give little more charging cycle, as of overall experience it is good.
    forpriyank and T1570024183543 like this.
  19. cp915j
    Eclair May 24, 2021
    RazvanScutea likes this.
