193
OxygenOS 11.0.1.1 for the OnePlus 7 Pro and OnePlus 7
  1. Tobi 97
    Donut May 24, 2021
    Tobi 97 , via OnePlus 7 Pro , May 24, 2021 :
    Same issue here, even after the Update to 11.0.1.1 🙄 And battery draining still ongoing...
    And another issue that i always encounter, is that when the device auto rotated or i manually rotate it, and i pull down the notification center after that, everything shows like it should, but not the quick toggles at the top. They are first blank and after 1-2 sec. they finally also appear😥
    14060001 likes this.
  2. TanjeetR
    Cupcake May 24, 2021
  3. Rishi_Pisces
    Gingerbread May 24, 2021
    Rishi_Pisces , via OnePlus 7 , May 24, 2021 :
    Please Read!
    mayur_c likes this.
  4. Udai Sharma
  5. FaZeAditya
  6. banmenau
    Eclair May 24, 2021
  7. Shinjuurou
    Honeycomb May 24, 2021
    Shinjuurou , May 24, 2021 :
    So after a few hours of usage I'm came to acception, that none of my problems are fixed (battery drain still higher then a 10, some pictures are loading correctly in my 3rd party Gallery App...) And I also facing the scaling problem in the calling screen. To be honest I'm a little disappointed. I hope future updates will work on some of these problems
    maxsinghania likes this.
  8. Shinjuurou
  9. Lucky_Sharma
  10. Agustin01
    Donut May 24, 2021
    Agustin01 , via OnePlus 7 Pro , May 24, 2021 :
    Guys, I'd recommend you to continue using your phone for a few more days and at least 3-4 battery cycles complete before writing and complaining about battery drain.
  11. RazvanScutea likes this.
  12. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator May 24, 2021
    Artemus , May 24, 2021 :
    Sure, go for it.
  13. asish022
    asish022 , via OnePlus 7 Pro , May 24, 2021 :
    Sorry to say that I am facing too much heating problem after the new update 11.0.1.1.. I have to switched off the phone again and again to cool down..
  14. Artemus
    Download CPU-Z from the Play Store and screenshot the thermal tab when you feel it getting "too hot".
  15. asish022
  16. manupatil11
  17. Rishi_Pisces
    GJM2 and DarenP like this.
  18. Rishi_Pisces
  19. avik331
    avik331 , via OnePlus 7 , May 24, 2021 :
    Go to recovery and clear cache, I had the same issue. It's gone now
    sam_015 likes this.
  20. avik331
    Anyone facing issues like heating, lag,etc. Kindly understand that this update is a huge one and I m definitely sure the entire rom package was reworked to better suit the device hardware. So if possible do a fresh install or else clean your cache and see. If problems still persist kindly attach a log to the support team.
    Hope this helps .
