193
OxygenOS 11.0.1.1 for the OnePlus 7 Pro and OnePlus 7
  1. eZtaRR
    Cupcake May 24, 2021
    eZtaRR , May 24, 2021 :
    Fine update - does anyone know if the mentioned fixes will bring better battery life,wwhich sseems tto have taken a hit after 11?
    And why are the numbers in dialer crazy small after the update?
    Akku143 likes this.
  2. kramik
    Honeycomb May 24, 2021
    kramik , May 24, 2021 :
    Same here.
    OP 7Pro 8/256GB Nebula Blue A11-OB4 PT
    sam_015 and Luarpc like this.
  3. kramik
    Vodafone does not yet have is active Wi-Fi calls, which is a shame.
    Luarpc likes this.
  4. mattb77705
    Gingerbread May 24, 2021
  5. O_DARSHAN_N_009
  6. O_DARSHAN_N_009
    mattb77705 likes this.
  7. mattb77705
    mattb77705 , via OnePlus 7T , May 24, 2021 :
    Thanks for the help, just curious do you know if I need to turn off VPN in order to receive the update? If you don't know that's cool I'll just look it up?
  8. P1569824951828
  9. 8_himanshured.Red8
  10. ClassicMain
    ClassicMain , via OnePlus 7 Pro , May 24, 2021 :
    I received and installed the update
    Sadly enough, OnePlus seems unable to fix this issues! The Gallery is STILL SLOW!
    It's S T I L L slow!
    And the improved system fluency, which i think is supposed to be a bugfix from the locked 60Hz issue a lot of people (including me) suffer from doesnt work aswell! The phone still is seemingly stuck at 60Hz!
    OnePlus needed over 7 months to release android 11. And even after 8 months the released software still has issues that a lot of people can reproduce!
    Unacceptable!
    B k, biglo30, Tobi 97 and 3 others like this.
  11. Hackerspy , via OnePlus 7 Pro Nebula Blue , May 24, 2021 :
    Try clearing app storage. I had it too before update and it has to do with Widevine. If you go in Netflix app settings, playback specifications you probably see the L3 instead of L1. Clear storage of the app (from Android settings) and check it back after re login.
  12. O1580049285802
    biglo30 and Tobi 97 like this.
  13. SANJAYRANGARAJAN , via OnePlus 7 Pro , May 24, 2021 :
    Hello Everyone,
    Am using OnePlus 7 Pro. Can anyone tell hows the battery after the recent update. Because I have reverted back to 10.3.8, If the battery works fine then I will go for Android 11. Kindly give me the exact feedback.
  14. GJM2
    GJM2 , May 24, 2021 :
    @Frarito
    I went from Beta 4 to 11.0.0.2 and after that to 11.0.1.1
    Use Oxygen updater app to update. Or get the rom links from google depending your model device, Global, EU, India, etc (XDA Developers for example).
  15. Frarito
    Frarito , May 24, 2021 :
    Thank you very much for answering, so if I download the full 11.0.1.1 rom and install it using the beta 4 updater in the settings, would it work?
    lordrico75 likes this.
  16. sam_015 likes this.
  17. ArpanC
    Cupcake May 25, 2021
    ArpanC , via OnePlus 7 , May 25, 2021 :
    Gallery loading still not fixed, not receiving some notifs and new problem that arose is the bluetooth disconnection every now and then. Sadge how this update was an upset too 😪
  18. pablolujan
    pablolujan , May 25, 2021 :
    Did y'all also finally fix the issue of being able to charge the phone and use wired headphones with a dongle? This is an extremely frustrating issue as it worked fine before and no longer does.
