193
OxygenOS 11.0.1.1 for the OnePlus 7 Pro and OnePlus 7
  1. avijana34
    Cupcake May 25, 2021
  2. Monoranjan12
    Donut May 25, 2021
    T1570024183543 likes this.
  3. Kum1r
    Gingerbread May 25, 2021
    reddevil55 and laikexpert like this.
  4. Tarun3249
    Tarun3249 , via OnePlus 7T Pro , May 25, 2021 :
    I updated my 7t pro device and now the proximity sensor is not working.and the gallary issue is still there it takes 10-15 sec to update gallary app when open,this is third time OnePlus has tried to solve gallary issue and they are failed.
    Please Help with proximity sensor issue! 🙏
  5. Satrajit Chakraborty
    Honeycomb May 25, 2021
    T1570024183543 and shayaanshaikh like this.
  6. Ajikdevadas
  7. shayaanshaikh
    Froyo May 25, 2021
  8. TxGopi
  9. Z1565940709320 , via OnePlus 7 Pro , May 25, 2021 :
    Stupidity level 90. Can't say a good word about the company that provides such an updates. After a couple of times I did informed that the placement of the keypad on lockscreen is awful. They replaced it back to normal place for the SIM PIN, but the crappy placement of the more actively using pad is here. OnePlus, great job guys, keep it this way so you will loose all of the potential new OP phone buyers who previously had OP 7 and OP 7 pro. In fact I didn't mentioned about major problems like battery drain and system stability issues that remains. Good luck OP, the game is over. Really sad to say that, but it's no doubt that I personally wont buy and won recommend anyone buying OP. And I really apologize for the hateful comment I posted, if you're happy with your OP than don't take my words close to your heart.
  10. K1560182305313
    K1560182305313 , via OnePlus 7 Pro , May 25, 2021 :
    Post this update, there are so many issues, whatsapp storage issues, when connected to laptop USB is not getting recognised, no option seen for file transfer and usb tethering, just phine is getting charged ... Please fix this ASAP!!
    Z1565940709320 likes this.
  11. ChristyCOCO
  12. ankitsinghai8080
  13. bcharles99
    bcharles99 , via OnePlus 7 Pro , May 25, 2021 :
    My problem is incoming calls are displayed after 3 to 4 Seconds... that is really annoying me
    Ajatshatru likes this.
  14. EugeneDevine
  15. Atik_Malek
  16. Raghava2706
    Raghava2706 , via OnePlus 7 Pro , May 25, 2021 :
    His reply would be:
    We would like to have this checked further and have the issue resolved for you at the earliest. We have dropped you a personal message and would request you to check it and do the needful.
    Hope to hear from you soon.
    Regards,
    Mujtaba
    B k likes this.
  17. V1560165685313
    reddevil55 likes this.
  18. HRG_Henry
    Froyo May 25, 2021
    HRG_Henry , via OnePlus 7 Pro , May 25, 2021 :
    After few hours of usage I'm glad to say that all of the issues I had before are gone.
    Automatic screen brightness is better than ever, WiFi stays connected, both SIMs work etc.
    Too soon to tell about battery but at least no heating issues.
    If it stays like this I would applaud 1+ for finally fixing all the issues.
    Yash Narain likes this.
  19. ankitsinghai8080
