140
OxygenOS 11.0.1.1 for the OnePlus 7T Pro and OnePlus 7T
  1. ghostofcain
    Marshmallow Jul 23, 2021
    ghostofcain , Jul 23, 2021 :
    I've no idea, I seriously thought OnePlus where flying to the wire, again.
    As long as you are happy with fragile hardware, my 4xl was replaced twice in 9 months, and you think OnePlus CS is clueless.
  2. Gokul7373
    Honeycomb Jul 23, 2021
    Gokul7373 , via OnePlus 7T Pro , Jul 23, 2021 :
    Haha that is fuckplus.....now you should lift down that fuckplus from your shoulder......
    oldusername likes this.
  3. J1577769579265
    Gingerbread Jul 23, 2021
  4. X1570717455902
    X1570717455902 , via OnePlus 7T , Jul 23, 2021 :
    Yah well OnePlus also offers the same plastic shit for that price
  5. Shubham8550
    Froyo Jul 23, 2021
    Rishi317 and kunu7458 like this.
  6. D1600610555193
    kunu7458 likes this.
  7. D1600610555193
  8. ghostofcain
    It's not the plastic it was the internal hardware that crapped out on me rendering the handset inoperable, in all the time of using smartphones I've never had to RMA one, let alone two handsets. And the worst of it I was warned continually before I took the jump.
    I believe Google play system updates are the purview of GOOGLE, a quick web search will tell you how to manually install them.
  9. Javvadibabajee
    kunu7458 and E1596960809058 like this.
  10. E1596960809058
    Froyo Jul 23, 2021
  11. hitesh_jagdish
    Froyo Jul 23, 2021
  12. MrDJ83
    h1ghland3r and kunu7458 like this.
  13. Wellington Ferreira
  14. Ionel Malasinc
    Ionel Malasinc , Jul 23, 2021 :
    Speaking of updating Google Play:
    The last time I reinstalled the OS I did the following steps:
    1) return to OS10 with the installation of the corresponding package on this link:
    https://forums.oneplus.com/threads/...or-the-oneplus-7t-and-oneplus-7t-pro.1379873/
    2) installation of the OS10.0.14 HD01BA iteration that holds it saved in the PC;
    3) manual updating of the Google Play system, which after the update is at the level of June 1, 2021;
    4) I updated to OS11.0.1.1.HD01BA and the update to the Google Play system was kept on June 1, 2021.
    Mention that I own OP 7T Pro HD1913 (EU)
    I think that OS11 has an error that does not allow updating the Google Play system, and this must be solved by OnePlus, obviously if it wants to ...😉
    Whoever wants can try ...
    Success!
  15. akhileshdk
    Eclair Jul 23, 2021
    Rishi317 likes this.
  16. Alexander Kazko
    Froyo Jul 23, 2021
    Totsquest and GianJames15 like this.
  17. dimitri_1980
    Donut Jul 23, 2021
  18. Dpack
  19. alex.nicolae
  20. frozenalex91
    Froyo Jul 23, 2021
    frozenalex91 , via OnePlus 7T Pro , Jul 23, 2021 :
    We only buy the hardware, soft is dead from the start. Some updates here and there but no hassle.
