140
OxygenOS 11.0.1.1 for the OnePlus 7T Pro and OnePlus 7T
  1. premchandra1993
    Gingerbread Jul 25, 2021
  2. A.Jeyasankar
    A.Jeyasankar , via OnePlus 7T , Jul 25, 2021 :
    kunu7458 likes this.
  3. fidanh
    Cupcake Jul 25, 2021
    fidanh , Jul 25, 2021 :
    I am having the wifi connection issue since the very first update to Android 11. I tried resetting settings, wiping the cache, enable and disable accelerated tethering on developer mode, but none of them work.
    I have to toggle on and off with wifi to get connected to a network and the connection drops after a while. When this does not work I have to restart the phone and only then it connects to my home or work network.
    Advice or instructions highly appreciated.
    TheBabaYaga, kunu7458 and Anzik like this.
  4. OneplusLover.
    OneplusLover. , via OnePlus 7 Pro , Jul 25, 2021 :
    Bro tobe honest ,
    Im really regretting buying this phone now ! Coz of no software support and bug fixing , then what's the use of this remote control like device!! Tell me
  5. Sam197
    Jelly Bean Jul 25, 2021
    Sam197 , via OnePlus 7T , Jul 25, 2021 :
    If your router support 2 channel, delete one of them.
    Go to smart WiFi connection and disable everything.
    Hope that works for you
  6. DavidLightman
    kunu7458 and R1ch4t like this.
  7. nabor
    Donut Jul 26, 2021
  8. ItsArunchauhan
    Eclair Jul 26, 2021
  9. kunu7458 and Lemillion like this.
  10. MarshaLOP and kunu7458 like this.
  11. Sam197
    Jelly Bean Jul 26, 2021
    Sam197 , via OnePlus 7T , Jul 26, 2021 :
    Any time you switch between stable and beta it ll wipe your phone,so backup before you switch.
  12. Chinaboy5216 , via OnePlus 7T Pro McLaren Edition , Jul 26, 2021 :
    You can, see the OB5 thread.
    I followed the guidance of zer0se7en and successfully have my 1+7TPro McLaren on stable now without data loss.
    Be sure, if you try it, to follow his steps exactly! Good luck.
  13. TheBabaYaga
    Froyo Jul 26, 2021
    kunu7458 and Abhilash995 like this.
  14. TheBabaYaga
    Froyo Jul 26, 2021
  15. nabor
    Donut Jul 26, 2021
    nabor , via OnePlus 7T Pro , Jul 26, 2021 :
    Could you please share the link? Thanks
  16. OneplusLover.
    Gingerbread Jul 26, 2021
    OneplusLover. , via OnePlus 7 Pro , Jul 26, 2021 :
    Really guys , this android 11 has destroyed my 7 pro's haptic engine , it makes wired sounds and doesn't feel like before!! It feels very pathetic , and when I take it to the "String vibration pattern" it makes a tickling sound . 😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭😭.
    They'll have to pay for this mistake one day!😞😖
    Totsquest and kunu7458 like this.
  17. G1594867602845
    Froyo Jul 26, 2021
  18. gauthampaik
    Froyo Jul 26, 2021
    gauthampaik , via OnePlus 7T , Jul 26, 2021 :
    Does anyone else face this? OP might say the camera is actually damaged. But it's not, because it perfectly works after rebooting the phone. So it's clearly not a damage but a bug.
  19. Avadhoot9075
    Eclair Jul 26, 2021
    alex.nicolae and kunu7458 like this.
  20. Javvadibabajee
