83
OxygenOS 11.0.1.1 for the OnePlus 8 and OnePlus 8 Pro
  1. Balaji2828
    Honeycomb Nov 7, 2020
    Balaji2828 , Nov 7, 2020 :
    Yes 100%
    #61
  2. W1604758648440
    Cupcake Nov 7, 2020
    W1604758648440 , via OnePlus 8 Pro , Nov 7, 2020 :
    persistent problem of the delay with which notifications are opened. it's very annoying
    when I pull down the notification bar and click on a notification there is a delay of about a second
    #62
    H1605699997189 and MilanDroppa like this.
  3. xByt3z
    Eclair Nov 7, 2020
    xByt3z , Nov 7, 2020 :
    This update is a bit of a disaster. Few points to notice:
    - This is the first time an update installed **automatically**.
    - I got the IN11AA (NA) update installed on a IN11BA (EU) device
    - This was automatically and forced installed while I am on the open beta, and this WIPED all my data when I woke up.
    What happened here?
    #63
    geoxar and I1572052715870 like this.
  4. #64
  5. Swejuggalo
    Community Bug Hunter Nov 7, 2020
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Nov 7, 2020 :
    This update is halted due to this
    #65
  6. #66
  7. safcio
    Cupcake Nov 7, 2020
    safcio , via OnePlus 8 Pro , Nov 7, 2020 :
    Same problem in Poland.
    #67
  8. #68
  9. MOLmixaRU
    Cupcake Nov 7, 2020
    #69
  10. Dp_pauls
    Cupcake Nov 7, 2020
    Dp_pauls , via OnePlus 8 Pro , Nov 7, 2020 :
    Same to me...
    #70
  11. Dp_pauls
    Cupcake Nov 7, 2020
    Same to me...
    #71
    Heffaklumpen likes this.
  12. xByt3z
    Eclair Nov 7, 2020
    That's great to know but that really doesn't help my and potentially many others' case.
    This should be tested before it gets pushed. You will immediately notice when NA updates are pushed to EU devices. You will instantly notice when you start up your phone after the update and it says "Wiping...."
    Updates shouldn't be automatic if OnePlus is notorious for doing things like this. (the Android 11 DP2 also had many people wake up with a bootloop!). You can quote me on this: This isn't the first time, and definitely not the last time either.
    #72
  13. PlugaruTudor
    Froyo Nov 7, 2020
    PlugaruTudor , Nov 7, 2020 :
    Where I can download the build to switch from OB3 to stable EU version?
    I am aware of the full wipe, just need the .zip file
    #73
    Ocw likes this.
  14. Unknown1plus
    Froyo Nov 7, 2020
    Unknown1plus , via OnePlus 8 Pro , Nov 7, 2020 :
    Can you try clearing cache n storage of your netflix and restart your phone? I would love to know if it solve any?
    #74
  15. Siddhant_SP
    Froyo Nov 7, 2020
    #75
  16. Ján Hirner
    #76
  17. Androwar
    Donut Nov 7, 2020
    #77
  18. glideleo
    Donut Nov 7, 2020
    #78
  19. PlugaruTudor
    Froyo Nov 7, 2020
    #79
  20. Swejuggalo
    Only source I know so far... No rollback needed. Just install over beta 3 (still wipes though)
    #80
