83
OxygenOS 11.0.1.1 for the OnePlus 8 and OnePlus 8 Pro
  1. MosheChupak
    Cupcake Nov 15, 2020
  2. shwongdi
    Honeycomb Nov 15, 2020
  3. pas-pas
    Jelly Bean Nov 15, 2020
    pas-pas , via OnePlus 8 Pro Glacial Green , Nov 15, 2020 :
    If you check some posts, indian users aren't also happy with OOS11.
    OnePlus+pro likes this.
  4. Tong_Yu
    Tong_Yu , via OnePlus 8 Pro , Nov 15, 2020 :
    When will be the NA update? I am quite annoyed with the update failure in PUBGM in play store.
  5. Vanstra
    Gingerbread Nov 15, 2020
    Vanstra , Nov 15, 2020 :
    Even though 5G is activated by my carrier in the Netherlands, I cannot select and activate 5G on my Oneplus 8 Pro. The 5G option was available and working in the Open Beta 1 version I had installed. Later in the next Open Beta 2 and 3, and also in this latest stable version, 5G isn't working and selectable anymore. I'm not amused. Especially because I bought the Oneplus 8 Pro back in May for it's 5G.
  6. Naidu_Koyilada
    Naidu_Koyilada , via OnePlus 8 , Nov 15, 2020 :
    There is an issue with "SMS ringtone & vibration" & "Default notification sound", I set SMS ringtone & vibration tone as "Free" and Default notification sound tone as " Meet". But when I get any SMS or notifications I'm hearing the tone "Meet" only.
    Please fix the issue
  7. Dimi Dimitrov
    Dimi Dimitrov , Nov 15, 2020 :
    Yes,you can.
    Issues will not be fixed soon.
    They will focus on 8T now.
    Early next year is expected series 9.
    So,no time for 8 series.
    Now I'm stay on 10.5.13.
    And phone working very good.
  8. Frostywuff
  9. rupes_
    Froyo Nov 15, 2020
  10. Piotr_Kowal_Properties
    Donut Nov 15, 2020
    Piotr_Kowal_Properties , Nov 15, 2020 :
    Hey Programiści z ONEPLUS! czy możecie coś zrobić, aby telefon nie przypominał mi co dwa dni o tym, że mogę go zaktualizować do wersji 11 ???!!! Po testach 11 wróciłem do 10, teraz jest super, i chcę, aby to tak zostało. Albo inaczej mówiąc: NIE CHCĘ 11! Najzupełniej wystarczy mi wersja 10! Zróbcie coś z tym, bo nie po to wydałem 1000 EUR na telefon, abym się teraz nim irytował! Chyba że chcecie, aby to był mój pierwszy, a zarazem ostatni OnePlus...
  11. AjayTagadOP8
    AjayTagadOP8 , via OnePlus 8 , Nov 15, 2020 :
    Screen Cast Not working Properly
    Why ?
    Not connect to the my led
    Other brand screen Cast is Working fine
    Why one plus not work this feature
    Pls any solution of this issue
  12. E1599187715290
    M1601273511115 and shwongdi like this.
  13. shwongdi
    shwongdi , via OnePlus 8 , Nov 15, 2020 :
    Maybe that's why you're getting good SOT. I'm noticing keeping the aod on is pulling a lot of battery through the day and barely giving 5-6 hrs of sot. OnePlus really needs to optimize the AOD so that it doesn't drain so much power
  14. shwongdi
    Right?? I've noticed this too. The photos have become blurry and optimisation of the image is really poor. Also I've noticed the camera app hangs a lot while launching and lags while using
  15. sujay89
  16. Angelo_93
  17. Frostywuff
  18. eddiedimitris
    eddiedimitris , Nov 15, 2020 :
    Good evening I had the 8 pro a few months ago and I want to get it again. I wanted to ask on android 11 now have they put the google dialer or have they kept the oneplus? Also compared to before the battery is doing worse? Also in your opinion beyond the subject of the camera that elsewhere has an advantage over the 8t? Thank you very much!
  19. E1605279871188
    Froyo Nov 15, 2020
    E1605279871188 , Nov 15, 2020 :
    Can you get 5G after update?
