81
OxygenOS 11.0.1.1 for the OnePlus 8 and OnePlus 8 Pro
  1. amdy
    Eclair Nov 20, 2020
    amdy , via OnePlus 8 Pro , Nov 20, 2020 :
    I got the update today. Haven't downloaded it yet. I will loose all the data if I use install it right ? I'm on stable channel. Haven't installed any open betas and the update is normal one..
  2. speedlever
    Honeycomb Nov 20, 2020
    speedlever , via OnePlus 8 Pro , Nov 20, 2020 :
    One item of note. As previously reported, gcam is broken with the 11.0.1.1 upgrade. I had both Arnova and Urnyx gcams installed and both were broken. But I rarely used them anyway since the 8 pro camera is so good. I'll install new gcams once they get fixed for this oos upgrade.
  3. speedlever
    To the best of my knowledge, the only people who lost data were accidentally uograded from beta to stable. And that's a known thing anyway. The problem there was people were upgraded from beta to stable without warning.
    I just upgraded stable oos 11.0.0 to 11.0.1.1 and no data loss here. You will be safe. I suggest you wipe the system cache from recovery after the upgrade. Then reboot.
  4. amdy
    Eclair Nov 20, 2020
    Thanks. How is it ? The update ? Have you experienced any bugs till now ?
  5. speedlever
    No issues other than the upgrade broke both gcams I had installed. No big deal. I mainly use the stock camera anyway. When the gcams are fixed, I'll reinstall them.
    So far I'm not aware of any other issues.
    amdy likes this.
  6. RajaKumar203
    Cupcake Nov 20, 2020
  7. speedlever
  8. docnok63
    Jelly Bean Nov 20, 2020
    speedlever likes this.
  9. E1588527729676
    E1588527729676 , Nov 20, 2020 :
    I just updated from beta 3 to beta 4 and lost all my data, so I would not consider this issue resolved if you are wondering whether it's still necessary to apply the fix in the original post.
  10. anjosuarez
    Donut Nov 20, 2020
  11. speedlever
    That's unfortunate. I've been tempted to try the beta. But always hated the thought of the factory reset in order to return to the stable channel. So I stick with the stable versions.
  12. Mohammed2m2
    Mohammed2m2 , Nov 20, 2020 :
    Is there any new features?
  13. Franz Maurer
    Donut Nov 20, 2020
  14. MENINBLK
    Froyo Nov 20, 2020
    MENINBLK , Nov 20, 2020 :
    DONE !!
    OnePlus IN2025
    Running OOS 11.0.1.1.IN11AA, MAGISK 21.1, NovaLauncher 6.2.15
    Unlocked and Fully Rooted
    Thank you !!
    docnok63 likes this.
  15. Ján Hirner
    Gingerbread Nov 20, 2020
  16. Nielle17
    Cupcake Nov 21, 2020
  17. cls55
    Froyo Nov 21, 2020
  18. docnok63
    Jelly Bean Nov 21, 2020
    cls55 likes this.
  19. Ilan.Maman
    Ilan.Maman , via OnePlus 8 Pro , Nov 21, 2020 :
    Me too received the notice
    But nothing to download. I updated to latest ota when it was in the first day that it was out and i think that it was not good.
    Where can i download the update ? Besides ota and oxygen updater?
    Thanks
  20. cls55
    Froyo Nov 21, 2020
