94
OxygenOS 11.0.10.10 (NA & EU) and 11.0.9.9 (IN) for the OnePlus 8T
  1. chinmayshitut , via OnePlus 8T Aquamarine Green , Sep 4, 2021 :
    2 screenshots taken just 4 minutes apart of this battery drain.
    It kind of negates buying a phone with 4500 mAh battery.
    Arun_R likes this.
  2. SosukeAizen
    Eclair Sep 4, 2021
    varun026 and vbas1l like this.
  3. Youssef.95
    Donut Sep 4, 2021
    Youssef.95 , Sep 4, 2021 :
    Don't worry, Oneplus is working on a new update to fix (imaginary) bugs and bringing new features(bugs)
  4. SyamKG likes this.
  5. Revanth Raman
    Donut Sep 4, 2021
    Revanth Raman , via OnePlus 8T , Sep 4, 2021 :
    I'm surprised to see fellow mates complaining about battery drain. However, I am not facing any battery drain as such. Probably closing all your apps and restarting your phone should make it better perhaps.
  6. RafeequeRq
    Cupcake Sep 4, 2021
  7. vbas1l
    Gingerbread Sep 4, 2021
    Q1614413158235 likes this.
  8. vbas1l
    vbas1l , via OnePlus 8T Aquamarine Green , Sep 4, 2021 :
    Dont just believe in this inbuilt battery history menu. Use Accubattery app and you can see the difference.
  9. Nbalugas
    Honeycomb Sep 4, 2021
    Nbalugas , via OnePlus 8T Lunar Silver , Sep 4, 2021 :
    Today I had the experience of fully charging the battery and waiting for the drop to 99%. The result was good! If you are having problems with the battery, take the battery to 0% and then they will adjust again to your usage.
    Loki10 likes this.
  10. Im.neeraj
    Froyo Sep 5, 2021
  11. arandommudkip
    Eclair Sep 5, 2021
    arandommudkip , Sep 5, 2021 :
    Horrible battery drain after this update. Don't even get 5 hours of SOT without gaming at all.
  12. MD1101
    Honeycomb Sep 6, 2021
    MD1101 , via OnePlus 8T , Sep 6, 2021 :
    Anyone facing weird system lag on 8t ? I am facing this issue daily. Restarting or clearing cache from recovery seems to work for few hours. Reported this multiple times. Please reply if anyone is facing this issue.
    Q1614413158235 and abhinav6915 like this.
  13. abhinav6915
    Donut Sep 6, 2021
    abhinav6915 , via OnePlus 8T , Sep 6, 2021 :
    Yes a bit stuttering and lagging in notifications
  14. abhinav6915
    Donut Sep 6, 2021
    Certainly not as smooth it used to be when it was new
  15. Q1614413158235
    Cupcake Sep 6, 2021
    Q1614413158235 , via OnePlus 8T , Sep 6, 2021 :
    After the update the Phone heats up significantly more during charging, which then also drops it's refresh rate and performance. The stutters are noticeable and annoying and the battery life has also decreased. The screen on-time which was 6-6.5 hrs earlier has dropped to 5 hrs. The other enhancements may not be as useful as detrimental the update has been to the phone's performance.
  16. Q1614413158235
    Cupcake Sep 6, 2021
    Absolutely facing this screen stuttering and usually it is after the Phone heats up, which again is after this update
  17. SachinSaini4745
    Donut Sep 6, 2021
    manjuhyr59 and alfoph like this.
  18. P1620320109924
    Cupcake Sep 6, 2021
    P1620320109924 , via OnePlus 8T , Sep 6, 2021 :
    90 fps not working please send update for it i am unable to earn as its not working fine bullet not registering and senstivity issue please resolve it its my earning i am a youtuber
  19. MD1101
    Oh then you are on the safer side, cause my phone straight away is unresponsive for 2 - 3 minutes with weird beep noice. Sometimes the system app crashes and takes me to lock screen
    It is weird and frustrating at this point.
    F1508326039999 likes this.
