104
OxygenOS 11.0.2.1 for the OnePlus 7 Pro and OnePlus 7
  1. YashPanchal097
    Froyo Jul 29, 2021
    YashPanchal097 , via OnePlus 7 , Jul 29, 2021 :
    I set advanced screen calibration & amoled wide gamut in advanced, but whenever I play HRD videos on YouTube, a screen turns from cold to slightly warm. This happens in previous versions and continues to happen in this latest version. IS THIS A BUG ?
  2. YashPanchal097
    Froyo Jul 29, 2021
  3. B k
    Ice Cream Sandwich Jul 29, 2021
    B k , via OnePlus 7 Pro , Jul 29, 2021 :
    If u r talking about opening notifications from notification panel, then NO. Same issue is still there, atleast for me yes🤷🏻‍♂️
  4. Harsha09
    Gingerbread Jul 29, 2021
    Harsha09 , Jul 29, 2021 :
    Hey @akks bro while using oxygen updater for updating will i get further updates from ota or should i use this method(oxygen updater apk)
  5. dudik
    Froyo Jul 29, 2021
    dudik , via OnePlus 7 Pro , Jul 29, 2021 :
    Factory reset? It usually takes me around 50 minutes to set everything up. First try that, it should do the job. I doubt they can fix it if the problems are there because system files are interrupting each other. (At least i guess how it works of factory helps)
  6. Jammy.01 , via OnePlus 7 Mirror Gray , Jul 29, 2021 :
    I too have same query, anybody has solution for this process?
  7. akks
    Lollipop Jul 29, 2021
    akks , Jul 29, 2021 :
    You will get future updates as OTA even if you sideload using oxygen updater, no issues
    D.Sai Suhail Baba and Liehjan like this.
  8. gdsingh94
    Jelly Bean Jul 29, 2021
    gdsingh94 , via OnePlus 7 , Jul 29, 2021 :
    I use oxygen updater generally to update my phone and this time i got the update via OTA..
  9. akks
    Can you share your complete battery stats at around 10% battery level? Check what's draining battery more. Some 3rd party apps unnecessarily run in the background. If you don't want it's background activity, you can individually select the particular app info- battery- select "optimise". It'll be intelligent control by default. Screenshot_20210729-164748.jpg
  10. FaZeAditya
    FaZeAditya , via OnePlus 7 , Jul 29, 2021 :
    Cons.
    1. Old security patch
    2. Wifi not giving speed as expected. Before update done a speed test on same network and server. The speed was 50mbps. After the update it was 22mbps.
    3. Animations are smooth, but speed not improved.
  11. sam1803
    Donut Jul 29, 2021
  12. Liehjan
    The Lab Reviewer - OnePlus Buds Pro Community Expert Jul 29, 2021
    Liehjan , Jul 29, 2021 :
    1. It isn't old, it follows their bi-monthly schedule.
    3. If you want more speed you can change animation speed in developer settings to 0.5x
  13. i.rahilsayed
    Eclair Jul 29, 2021
  14. JFaraday
    Cupcake Jul 29, 2021
    JFaraday , Jul 29, 2021 :
    So, nothing in this update to fix the network & Wi-Fi issues on the 7pro? That is a bit disappointing. Since I updated to OS11, I have problems through out the day with my cell network provider and my Wi-Fi connection which I did not have with OS10.
    Hope you will fixe that eventually. Thanks for reading and listening
  15. Stephen Edwin
    Eclair Jul 29, 2021
  16. mrmatrix
    Froyo Jul 29, 2021
  17. Sharif.hero
    SubashArvind071 likes this.
  18. Cojy
    Cojy , Jul 29, 2021 :
    It has nothing to do with the battery as the device is plugged in. If I had no battery at all that would go: android 10 no pb, android 11, device shutting down because of lack of power. Also batteries don't magically die in one day.
  19. F1588911114381 , via OnePlus 7 Pro , Jul 29, 2021 :
    This is scrap. I did naw install this os. Suddenly my phone is over heating. It's very scary. I want to rollback os 10. Plzzzzz help me. Otherwise I leave the all OnePlus device. I have op7 pro. Plzzz help me . You are cheater. Bigg cheater. God will distroy your company. If you not help me
    ABINASH_PANDA likes this.
