105
OxygenOS 11.0.2.1 for the OnePlus 7 Pro and OnePlus 7
  1. Boogeyman_real
    Gingerbread Jul 29, 2021
    Boogeyman_real , via OnePlus 7 Pro , Jul 29, 2021 :
    Yes. I do understand that factory reset helps you. But my point is that it is the ultimate solution and most users wouldn't want to wipe their device only if their speaker isn't working right. Just an example. I won't compare with other brands because every brand has their own problems.
  2. manushd2
    Cupcake Jul 29, 2021
    laikexpert likes this.
  3. Satrajit Chakraborty
    Honeycomb Jul 29, 2021
    Satrajit Chakraborty , via OnePlus 7 , Jul 29, 2021 :
    After every major os updates, factory reset should be done but not mandatory for incremental updates. Sometimes cache wipe may help after every incremental updates. I myself did a factory reset and I am almost using a bug free os other than some minor negligible glitches.
    perooo2, Pawcio62432 and imritesh like this.
  4. Satrajit Chakraborty
  5. imritesh
    Donut Jul 29, 2021
    imritesh , via OnePlus 7 Pro , Jul 29, 2021 :
    That why i suggest after 6 to 7 months.... because after using 6 to 7 months we do lots of activities in our phone...and lots of unwanted things added and we can't track each of them. So when we reset our phone we know what we actually need. It's just a personal opinion bro. It helps me that why i suggest.
    gdsingh94 and Boogeyman_real like this.
  6. Boogeyman_real
    I agree that factory reset helps. But nobody would prefer wiping their daily driver. Will it be acceptable if you get a windows update and you have to format your whole laptop and start from scratch even if you have a backup if there are some bugs?
    ShinyCoin and gdsingh94 like this.
  7. yashvidrohi likes this.
  8. Jerinjhonson , via OnePlus 7 Mirror Gray , Jul 29, 2021 :
    Bugs still there
    1.very flat Haptic feedback now not optimised
    2.Take too much loading time for app openings
    3.double tap to wake take too much time
    4.Battery drain issue still there
    5.Ul lag is there
    7.Performance issue
  9. Artemus
    Community Hero 2020 Jul 29, 2021
    Artemus , Jul 29, 2021 :
    When did you last wipe your phone?
  10. Daasty
    Daasty , via OnePlus 7 Pro , Jul 29, 2021 :
    Updated todavi from OOS10, can't see any heating or battery issue. Finally an usable update! Months waiting for what it should have been on launch.
    mrmatrix and laikexpert like this.
  11. mrmatrix
    Eclair Jul 29, 2021
    mrmatrix , via OnePlus 7 Pro , Jul 29, 2021 :
    The only problem i have in your comment is 3. Double tap take too much time because of animation. I tried to change animation in settings but i couldnt find.
  12. GJM2
    GJM2 , Jul 29, 2021 :
    I dunno know what kind of OP7 Pro are you people buying and using.
    Mine, 2 years old. Running flawlessly as the first day. Not problem at all, no overheat, no lag, no drag battery, no wifi nor 4G conexion matters, no slow double tap, nothing. Android 11 0.2.1, L1 HBO & Netflix in high definition, May Google Play and June security patches. Waiting 5G for buying the next OP 10 Pro 😍.
    Screenshot_20210730-001119.jpg Screenshot_20210730-001030.jpg Screenshot_20210730-001159.jpg
    P.D: Next time try buying EU model in China (Al#expr*ss for Example) and use Indian Language. All my chinese OP models had no problems at all, never.
  13. Jav P
    Honeycomb Jul 30, 2021
    Jav P , via OnePlus 7 , Jul 30, 2021 :
    Which animation do you mean? Fingerprint animation (Customisation) or system wide (Developer Options)?
  14. Daasty
    Daasty , via OnePlus 7 Pro , Jul 30, 2021 :
    WTF! Battery is at 50°C Charging! Just playing some YT meanwhile, just updated today and it wasn't getting warm. OOS is still crap I guess..
  15. Kiranrshetty
    Donut Jul 30, 2021
    isohaibkhan007 and laikexpert like this.
  16. siddartha.ps
    Froyo Jul 30, 2021
    siddartha.ps , via OnePlus 7 Pro , Jul 30, 2021 :
    How is auto brightness calibration? Is it improved?
  17. isohaibkhan007
    Gingerbread Jul 30, 2021
    isohaibkhan007 , via OnePlus 7 Pro , Jul 30, 2021 :
    Same From India and no problems at all
  18. Kiranrshetty
    Donut Jul 30, 2021
    siddartha.ps likes this.
  19. Gemilan
    Eclair Jul 30, 2021
    Gemilan , Jul 30, 2021 :
    Thanks, I deleted and reinstall the app and the update appeared, such a weird bug :)
  20. Adi_2019
    Ice Cream Sandwich Jul 30, 2021
