105
OxygenOS 11.0.2.1 for the OnePlus 7 Pro and OnePlus 7
  1. Boogeyman_real
    Gingerbread Jul 31, 2021
    Boogeyman_real , via OnePlus 7 Pro , Jul 31, 2021 :
    Have you tried turning off bluetooth scanning?
  2. harsh_choxi
    Donut Jul 31, 2021
    Lucky_Sharma likes this.
  3. V1560165685313
    Honeycomb Jul 31, 2021
    V1560165685313 , via OnePlus 7 , Jul 31, 2021 :
    Switch to new stable.. this is most stable update of 11 . I would say. My L3 issue also solved after this update. And I can say battery life is bit better
  4. Artemus
    Community Hero 2020 Jul 31, 2021
    Artemus , Jul 31, 2021 :
    Did you follow any guides? There are a ton available. Also, that'd be considered a frivolous lawsuit since they're not in charge of it.
  5. venkyred20052
    venkyred20052 , via OnePlus 7 , Jul 31, 2021 :
    I see many people complaining about L3. Is this issue there for all users or only to few people?
    I see mine as L1 certification when checked using drm info app. I don't know much about L1 vs L3, but just confirming mine is showing L1. I am using OP7 Indian varient for reference.
    Also I don't have any issues with VoLTE and VoWiFi. Both are working fine as usual same as OB builds.
    Only issue that I can see is battery backup. That again depends on usage and person to person. But I feel it's same as OB build and no improvements.
    Prince_Vachhani likes this.
  6. VenkysB
    VenkysB , via OnePlus 7 Pro , Jul 31, 2021 :
    No its not for all users. After this update some of the users got the issue solved but some of the users still facing this issue even though they mentioned that they have fixed the issue in june update.
    I am also facing the same issue even after the update.
    It's really annoying and disappointing. OnePlus have HDR displays but still no HD support because of widevine issue
  7. VenkysB
  8. V1560165685313
    Check battery capacity with OnePlus app.
  9. v1kk1
    Froyo Jul 31, 2021
    v1kk1 , via OnePlus 7 , Jul 31, 2021 :
    In this update the screen recording doesn't record audio when selected internal audio e.g. if you want to record a zoom class meeting. Earlier it was working fine.
    Anyone experiencing the same issue?
  10. ABJ.RAJA
    Eclair Jul 31, 2021
    rtz2042 likes this.
  11. BomberBot
    Cupcake Jul 31, 2021
    BomberBot , Jul 31, 2021 :
    I am having issues after the update where the on screen buttons don't work at all and I am noticing much lag still. The update seemed to make things worse in general.
  12. rtz2042
    Eclair Jul 31, 2021
    rtz2042 , via OnePlus 7 , Jul 31, 2021 :
    After a wait of 2+ months, here we get an update which is good for nothing. I am still on L3 and not able to watch HD content on Prime/Netflix. Battery is draining faster too. OnePlus is showing big middle finger to older device users. I don't really they will be able to fix this issue.
    the_reckoner likes this.
  13. akhilraju91
    Donut Jul 31, 2021
  14. akhilraju91
    Donut Jul 31, 2021
  15. E1592318225451
    Eclair Jul 31, 2021
    E1592318225451 , via OnePlus 7 Pro , Jul 31, 2021 :
    What about battery drain issue n heating issue still there or not
  16. Sooraj1803
  17. Singhnaman
    Froyo Jul 31, 2021
  18. hareb95
    hareb95 , via OnePlus 7 Pro , Jul 31, 2021 :
    Im still facing issues in regards with apps, for example i use snapchat insta, botim and tiktok alot, all of a sudden i cannot load any video from the apps like i can scroll through the apps but no videos load and then i cannot accept calls on botim or Whatsapp so to fix this i have to either restart the phone and sometimes this dosent work so i have to reboot the phone..
  19. X1607446869263
    X1607446869263 , via OnePlus 7 , Jul 31, 2021 :
    it is better if add option to block any number series ...not only to block single number...like 999*******, 123******* ...it will be useful for so many..
