105
OxygenOS 11.0.2.1 for the OnePlus 7 Pro and OnePlus 7
  1. I1557911384926
    Froyo Aug 5, 2021
    I1557911384926 , Aug 5, 2021 :
    If I reboot all is OK for about a minute and then certain apps cannot connect to Internet. One app this happens with is oneplus community app.
    I am using a oneplus 7 pro with latest version of Android 11.
    Can anybody help with this issue.
    Thank you.
    T1570024183543 likes this.
  2. Artemus
    Community Hero 2020 Aug 5, 2021
    Artemus , Aug 5, 2021 :
    You've never wiped your phone? Well, that might be the cause then.
    Are you doing this over WiFi or mobile data?
  3. I1557911384926
    Froyo Aug 5, 2021
    The issue happens with both WIFI and mobile date.
    Yesterday I had no issues.
    I do not want to wipe phone I just want a solution to issue.
  4. Artemus
    The phone wiping was for the first guy in a double quote. I apologize if I made you think I was suggesting that to you as well. :)
    akks likes this.
  5. Jav P
    Honeycomb Aug 5, 2021
    Jav P , via OnePlus 7 , Aug 5, 2021 :
    Are you using an antivirus, ad-blocker or any other similar app? If so, make sure they are not blocking access to those apps.
  6. AbbasEsapzai
    Cupcake Aug 5, 2021
    AbbasEsapzai , via OnePlus 7 Pro , Aug 5, 2021 :
    I upgraded my OnePlus 7 Pro GM1915 to Oxygen 11. First the display would blink and shrink to a side of the screen. Someone in this forum suggested that I should factory data reset my phone. I did so and the problem went away but now there is a greater problem. When the screen turns black after inactivity for some time, it wouldn't light up again. All the buttons work but the screen wouldn't light up. I have to press and hold the power and volume up button together for 15-20 seconds to restart it. If you know about the solution to this issue, plz help me
  7. v1kk1
    Froyo Aug 5, 2021
    v1kk1 , Aug 5, 2021 :
    Reverted to 10.3.8 & didn't update the oneplus apps. with both battery optimization & ram boost turned off the system works great with good battery standby.
    mayur_c and Adi_2019 like this.
  8. dgnbrk
    Froyo Aug 5, 2021
    dgnbrk , via OnePlus 7 , Aug 5, 2021 :
    11.0.2.1 version of very stable working and battery drain is good,after I tested 10.0.1.0 version and it s giving better than performance
    U1549078778762 likes this.
  9. Ab14801
    Eclair Aug 5, 2021
  10. Pa3ck_96
    Froyo Aug 5, 2021
    Pa3ck_96 , via OnePlus 7 Pro , Aug 5, 2021 :
    This might seem strange and I'm currently monitoring the situation on my device, but try to enable RAM Boost in system settings. My device became unresponsive each day at around the same time and then soft rebooted itself. Since I re-enabled ram boost the issue didn't happen yet atleast today.
  11. AbbasEsapzai
    Cupcake Aug 5, 2021
    Its already enabled and I have faced this issue some 10 times since morning. Now I made the screen off time to 30 mins and am
    constantly using the phone since then to not face the issue again
  12. that1matt , via OnePlus 7 Pro Nebula Blue , Aug 5, 2021 :
    I had the same issue, follow the steps and it will get rid of the issue.
  13. R1601565790834
    Cupcake Aug 5, 2021
    R1601565790834 , via OnePlus 7 Pro , Aug 5, 2021 :
    When I'm getting a call I have to wait 10 sec to who is calling. Seriously what the **** is this? Released 3 updates didn't fix anything. With this new update many apps stops working, keep on freezing. And RAM management is worse after this update.
    I'm using 8gb ram and 256gb storage
    Why the **** I paid more for ram, I was using htc with 2gb ram previously, that htc was faster than this 8gb ram garbage.
    I'm not even doing heavy use-age.
    OnePlus sucks🖕🖕🖕
  14. Adi_2019
    Ice Cream Sandwich Aug 5, 2021
    Adi_2019 , Aug 5, 2021 :
    I keep ram boost and battery optimisation off always. Keep all frequently used apps open in background. Phone performs better this way.
    v1kk1 likes this.
  15. v1kk1
    Froyo Aug 5, 2021
    yup, same here as well.
  16. Priteshkadel
    Eclair Aug 5, 2021
    srangu and T1570024183543 like this.
  17. U1577368070780
    Cupcake Aug 5, 2021
  18. rtz2042
    Eclair Aug 5, 2021
  19. AkulaYoganand
    Donut Aug 5, 2021
    Skuis and T1570024183543 like this.
  20. v1kk1
    Froyo Aug 5, 2021
    I never had the widevine issue. its always been L1 in my case.
    rtz2042 likes this.
