104
OxygenOS 11.0.2.1 for the OnePlus 7 Pro and OnePlus 7
  1. sarahmic
    Honeycomb Aug 6, 2021
    sarahmic , Aug 6, 2021 :
    I have been testing for the last few days and agree that while charging the phone heats up quite a lot.
    This never happened to me before and i have my OP7P for 2 years now.
    Battery is still the same - not better and not worse.
  2. Rohan Bolla
    Gingerbread Aug 6, 2021
    Rohan Bolla , via OnePlus 7 , Aug 6, 2021 :
    Bro... You got bad luck... But disable "automatic system updates" in developer options to prevent it from doing so in the future.
  3. C1628189082897
    Cupcake Aug 6, 2021
    U1604472686617 likes this.
  4. GJM2
    GJM2 , Aug 6, 2021 :
    I use sometines this app. It checks your batery health out, recalibrates it and repair the parts damaged. It's very good, after 2 years I have a battery like a new one :)
    https://play.google.com/store/apps/details?id=com.batteryrepair.batteryrecovery
    And also follow these tips --->
    -The general android rule says depending on your region that, up to 60° or lower, cpu is safe. More than 100° unsafe.
    -The general android rule says depending on your region that, from 35° to 50° battery percent is quite common. Above 50°, starts to be dangerous.
    -Your device getting hot is quite normal when:
    1. You are charging it (dash mode usually).
    2. You are updating a new heavy OS.
    3. The first 4/5 cycles of charging after updating a new heavy OS.
    4. When playing or managing with heavy games or apps (that require high definition graphics).
    THE BEST THING TO KEEP SAFE YOUR BATTERY LIFE IS:
    -NOT keep charging battery when full charge is reached (100%).
    -NOT charge your battery below 15/20 charge percent (red mode).
    -TRY not to fully discharge the battery too many times.
    -USE your original charger device.
    -TRY not to expose and charge your device to hot or sun too much time.
    Anks Lee, sam_015, Netsky60 and 2 others like this.
  5. UnicornZ
    Ice Cream Sandwich Aug 6, 2021
    UnicornZ , via OnePlus Community App , Aug 6, 2021 :
    Buddy, this s a fake app 😄 don't fall for it. Software can't magically repair a hardware part.
  6. GJM2
    Could be true :). Maybe only calibrates it. Anyway much people comment a better manage and duration with dead batteries by perhaps magical spirits haha. I don't really think this app repairs battery. May be only optimizes it.
    I prefer follow the tips. They are more reliable :)
  7. Pa1KumarM
    Pa1KumarM , via OnePlus 7 , Aug 6, 2021 :
    Is this a promotion ???
    subhanu.bhattacharya likes this.
  8. GJM2
    No. Yur free to try it or not.
    I prefer as said before to follow the tips posted in the same message.
  9. UnicornZ
    DMaarten and XDeadshoTX like this.
  10. GJM2
    Yup. It's a fake. Anyway, after 2 years old. Capacity is still 75%.
    Not bad :)
    Sach716 likes this.
  11. SrikanthShenoy
    SrikanthShenoy , via OnePlus 7 , Aug 6, 2021 :
    I started having issues with my android auto after updating my phone to OS 11 and I found out that most of the users using it for android auto have similar issues. This update did not help on resolving this ongoing issue. Such a shame .. this will bey last one plus phone.
  12. subhanu.bhattacharya
    Donut Aug 6, 2021
    subhanu.bhattacharya , Aug 6, 2021 :
    Definitely a fake up. Promises to do the impossible.
    Reviews are most definitely clickfarmed.
    It's just a couple of animations.
    Try this out after running what is suggested here.
    Clear data + storage
    Run it again.
    You'd get the same animation and results, claiming that parts of the battery are bad, which it just a minute ago (in the previous iteration) had claimed to have fixed.
  13. J1577540243263
    Cupcake Aug 7, 2021
  14. U1604472686617
    Gingerbread Aug 7, 2021
    U1604472686617 , Aug 7, 2021 :
    Use the Oxygen Updater app from the Playstore.
    It downloads the rom from the Oneplus servers.
    It does not affect you receiving other OTA's later...
  15. L1575755917767
    Cupcake Aug 7, 2021
  16. Ankush__Chauhan
    Eclair Aug 7, 2021
    Ankush__Chauhan , via OnePlus 7 , Aug 7, 2021 :
    Battery is f**ked in this update.😡😡😡😡
    This is what OnePlus is doing with the previous generation phones. Just degrading their qu 1628321166506.jpg said:
    alities.
  17. laikexpert
    Honeycomb Aug 7, 2021
    laikexpert , Aug 7, 2021 :
    - Battery holds up much better
    - Phone does not heat up at all
    - Double tap to wake, works great
    - Notification panel works without problems.
    OnePlus 7 Pro (Model GM1913)
    OxygenOS 11.0.2.1 GM21BA
    Nova Launcher.
    P.S.
    Great update.
    Everything works without problems.
  18. James 007
    James 007 , via OnePlus 7 , Aug 7, 2021 :
    I don't do non of Ur BS steps look on my battery From onecrap service mode and yes it's 2 year's old.
  19. DarshhD07
    Cupcake Aug 7, 2021
    T1570024183543 likes this.
