104
OxygenOS 11.0.2.1 for the OnePlus 7 Pro and OnePlus 7
  1. Ab14801
    Eclair Aug 8, 2021
  2. Shooper
    Froyo Aug 8, 2021
    Shooper , via OnePlus 7 Pro , Aug 8, 2021 :
    I'm thinking highly unlikely as the amount of time they claimed to be giving updates is over.
  3. Vishraval
    Donut Aug 8, 2021
  4. O1567752746734
    Cupcake Aug 8, 2021
    Lasterko likes this.
  5. V1560165685313
    Honeycomb Aug 8, 2021
    V1560165685313 , via OnePlus 7 , Aug 8, 2021 :
    2year old with 91%?? How?? Any charging pattern.. because I replaced battery on completion of my 2nd year. Means just 1 month before and now I have 94%
  6. Luarpc
    Luarpc , via OnePlus 7 Pro Nebula Blue , Aug 8, 2021 :
    And so what? My phone is 2 year's old too, and the app OnePlus Diagnostic shows 92% battery health and Accubattery show's 94%.
    All you have to do is to know how to properly charge your battery's phone!
    V1560165685313 likes this.
  7. Thoufeekabdul
    Cupcake Aug 9, 2021
  8. V1560165685313
    Honeycomb Aug 9, 2021
    Luarpc likes this.
  9. PRERANAMORE
    Cupcake Aug 9, 2021
    T1570024183543 likes this.
  10. Adi_2019
    Ice Cream Sandwich Aug 9, 2021
  11. R.Peter
    R.Peter , via OnePlus 7 Pro Mirror Gray , Aug 9, 2021 :
    That'll always happen because games use more power, means will drain the be battery (technically everything you use drains the battery) and warm up the phone. Imagine your are running slow: you'll be hungry after a time, and sooner or later sweat to cool your body. Now if your run fast (you use more energy), you'll be hungry sooner and your body will require cooling sooner.
  12. x_jayreghe_x
  13. PRERANAMORE
    Cupcake Aug 9, 2021
    PRERANAMORE , via OnePlus 7 Pro , Aug 9, 2021 :
    But it never happened before....n phn started heating just after 15-20 m.
  14. Kruzer
    Gingerbread Aug 9, 2021
    Kum1r likes this.
  15. AMARjit4091
    Eclair Aug 9, 2021
    AMARjit4091 , via OnePlus 7 Pro , Aug 9, 2021 :
    Anyone else facing finger print scanner issues. The phone is getting unlocked via finger print but locked apps are not registering the finger print. I have tried restarting and clearing cache files. But nothing seems to change.
  16. R.Peter
  17. PRERANAMORE
    Cupcake Aug 9, 2021
  18. Anvesh_Bobba
    Donut Aug 9, 2021
    Anvesh_Bobba , via OnePlus 7 Pro , Aug 9, 2021 :
    I did face the same problem in previous version. But this update seems to fixed that.
  19. LucasKo
    Donut Aug 9, 2021
    LucasKo , via OnePlus 7 Pro , Aug 9, 2021 :
    I voice calls issue after this update when Im talking at the beginning of a call it all ok then suddenly I can't hear other person just some random words of part of words. After a minute or two it ok again. I thing other person is hearing what I'm talking anyway.
  20. Smileykalai
    Eclair Aug 9, 2021
    Smileykalai , via OnePlus 7 Pro , Aug 9, 2021 :
    I have OnePlus 7 pro with the latest update of oxygen os 10.0.2.1. build in that update lot of bugs are there like Over heating issue and quick battery drain issues and low volume (sounds) I'm facing. From 100 to 1 it's came only 4 to 5 Hours only for normal usage. With the gaming means it's only 2.30 to 3 only for 100 to 1 it's very bad update I have ever seen. OnePlus please fix this issue soon ASP.
