104
OxygenOS 11.0.2.1 for the OnePlus 7 Pro and OnePlus 7
  1. Ronak3567
    Gingerbread Aug 9, 2021
  2. Luarpc
    Honeycomb Aug 9, 2021
  3. Ronak3567
    Ronak3567 , via OnePlus 7 Pro , Aug 9, 2021 :
    Yea now its working... Actually there are 2 apks on version 1 the very first dsnt work but the 2nd version 1 apk worked... My battery health is 84%
  4. Luarpc
  5. Ronak3567
    Luarpc likes this.
  6. Luarpc
    Honeycomb Aug 10, 2021
  7. gg1+7
    Gingerbread Aug 10, 2021
    gg1+7 , via OnePlus 7 , Aug 10, 2021 :
    Since the past week i have been experimenting with the auto brightness feature turned on and off. Hv left it set to a brightness level which serves all my when I'm out in sun and indoor.
    Did notice significant battery backup improvement with the feature turned off.
    Seems Android system keeps calculating the same in the background which is a big battery drain.
  8. Tobi 97
    Donut Aug 10, 2021
    Tobi 97 , via OnePlus 7 Pro , Aug 10, 2021 :
    A short summary what the 11.0.2.1 Update improved for me and what not:
    Positive:
    - Battery Life significantly increased (f***ing finally)
    - overheating battery is significantly reduced, but still sometimes appears
    - overall Performance a little smoother, but still not ideal or comparable to A11
    - Security Patch Up to Date again
    Negative:
    - Bluetooth Bug still present (it just turns on itself from time to time)
    - Gallery Bug still present (once my Phone did load the last pictures for around 5 minutes!!! It were only about 3 new pictures!)
    - disappearing quick toggles still present (Happens when phone is rotated with Auto rotation on and after that pulling down of the notification shade -> quick toggles for WIFI etc. first not visible, only after 1-2 sec., but the rest of the notification shade is visible before that delay already)
    - glitchy Picture in picture-function (= playing for example YouTube Vanced while surfing the web)
    - graphical issues with the fingerprint (grey background behind it)
    Conclusion:
    So Oneplus, you still have some work to do!!
    By the way: Cache was wiped after the update and phone was not touched after that for about 30 min.
  9. Destro7
    Destro7 , via OnePlus 7 Mirror Gray , Aug 10, 2021 :
    Is anyone facing the issue with the battery ,idk if its the software problem
    But i am facing the issue that when using the phone and drainjng the battery form 100 to 0 , when it reaches 15 ,it suddenly drains battery like in a min and phone switches off
    HELP!
    Ammar_ and V1591614230508 like this.
  10. DhavalA
    Froyo Aug 10, 2021
    DhavalA , via OnePlus 7 , Aug 10, 2021 :
    Weather is not showing in shelf. Everyone is facing this issue. Why Dev's are not solving this?
    Pocket mode is also gone? Why removed important feature?
    Marcel_V, Velu03 and Arvind__Singh like this.
  11. V1591614230508
    Donut Aug 10, 2021
    V1591614230508 , via OnePlus 7 , Aug 10, 2021 :
    The battery life is very worst when I play BGMI with smooth and extreme for an hour the battery drains 50% of battery and while on standby 10-12% battery.In Android 10 I'm getting min 5hrs of SOT max 7Hrs SOT but in Android 11 I'm getting 2hrs-1 hour the charger is required when I'm taking my oneplus 7 out with me😂😂😂.the software needs very much battery optimization,the main problem is battery please resolve this issue ASAP in the next update. Please provide regular security updates rather than 2 months once or 3 months once.
  12. MadyKarthi
    MadyKarthi , via OnePlus 7 , Aug 10, 2021 :
    Still I am facing fast battery drain..
    While charging device getting heat...
    When OnePlus buds Z is connected, when attend incoming call. Automatically OnePlus buds z getting disconnects..
    T1570024183543 likes this.
  13. K1564599569555
    Cupcake Aug 10, 2021
  14. A1628599433339
    A1628599433339 , via OnePlus 7 , Aug 10, 2021 :
    After update oneplus7 (11.0.2.1) glitch comes in my phone ..it's automatically on dark mode and the color of the display keep coming and fading out.. can't use my phone coz it's effecting my eye..really worst update ...please help me out
  15. AlexBNice
    Eclair Aug 10, 2021
    AlexBNice , Aug 10, 2021 :
    11.0.2.1 works well on my 7 Pro. The phone doesn't get as hot anymore and battery lasts a bit longer.
    The only know bug that I experience and I'd like to see fixed, is when switching apps and music is playing, the music will pause for a second and resume playing.
    kramik likes this.
  16. wospino
    Ice Cream Sandwich Aug 10, 2021
    wospino , via OnePlus 7 Pro , Aug 10, 2021 :
    I changed it 3 days ago... Hehe
    V1560165685313 likes this.
  17. wospino
    I agree... For my op7 pro the only bug is related with the proximity sensor... Some times it stop working and a reboot is need to make it work again
  18. iulisimo
  19. Sagarshaikh likes this.
