104
OxygenOS 11.0.2.1 for the OnePlus 7 Pro and OnePlus 7
  1. Pa1KumarM likes this.
  2. Marchelius
    Froyo Aug 28, 2021
    Marchelius , Aug 28, 2021 :
    Hello.
    I had the same situation with my OP7
    You must use Unbrick Tool (for OP7 you find it here : https://forum.xda-developers.com/t/...l-to-restore-your-device-to-oxygenos.3954325/
    Choose last version of OOS10 (10.0.10 for EEA , 10.3.7 for Global), later download correct package with last version (10.3.8 or 10.0.11) and flash it from phone as a local update. Last thing is factory reset.
    fasly likes this.
  3. pcpremengg
    Froyo Aug 28, 2021
    T1570024183543 and fasly like this.
  4. fasly
    Cupcake Aug 28, 2021
    fasly , via OnePlus 7 Pro , Aug 28, 2021 :
    K brother tnx......i try
  5. Marchelius
    Froyo Aug 28, 2021
    Don't forget to install OnePlus USB drivers before.
    I downgraded my OP7 from 11.0.2.1 to 10.0.11 and my battery is alive again :)
    fasly likes this.
  6. Satrajit Chakraborty
    Honeycomb Aug 28, 2021
  7. Satrajit Chakraborty
  8. Satrajit Chakraborty
    Satrajit Chakraborty , via OnePlus 7 , Aug 28, 2021 :
    I will send you the logs as usual like I used to do before, you will reply with the same texts and won't do anything afterall. This is how you solve the issues👍
  9. R1528428787227
    Eclair Aug 29, 2021
    R1528428787227 , via OnePlus 7 Pro , Aug 29, 2021 :
    Exactly! Thanks for posting the link. Truth!
    laikexpert likes this.
  10. omar302
    Eclair Aug 29, 2021
    omar302 , Aug 29, 2021 :
    Google Play System August update is now available. I manually checked and it updated just now.
    D.Sai Suhail Baba likes this.
  11. kãräñ_90564
    Ice Cream Sandwich Aug 29, 2021
  12. Tedinetto
    Gingerbread Aug 29, 2021
  13. omar302
    Eclair Aug 29, 2021
    I just went to Settings> Security & Lock Screen > Google Play system update > Check for update. I did it today morning and hot the update. It downloaded and then a restart was required to finish.
    Sorry, I don't know. Maybe wait until the next update is available, just do not use the update from APKmirror (the small 20Kb update file).
    Tedinetto likes this.
  14. Appycool
    Eclair Aug 29, 2021
  15. Udai Sharma
  16. Pa1KumarM
  17. T1570024183543
    Ravitejanayudu likes this.
  18. Loubear likes this.
  19. Singhnaman
    Blue llama and Arvind__Singh like this.
