103
OxygenOS 11.0.2.1 for the OnePlus 7T Pro and OnePlus 7T
  1. Roei.e
    Honeycomb Aug 21, 2021
    Roei.e , via OnePlus 7T , Aug 21, 2021 :
    In android 10 i used to get 7 hours when getting to 20%
  2. Atanu95
    Froyo Aug 21, 2021
  3. Prnv89
    Eclair Aug 21, 2021
  4. Satya U
    Froyo Aug 21, 2021
    Satya U , via OnePlus 7T Pro , Aug 21, 2021 :
    For Widevine L1 issue I tried this idiotic solution but luckily it worked. : Disable Biometric Authentication in Google Play store and restart your device and now enable the biometric authentication and restart your device again. Clear your Amazon Prime and Netflix App cache and try playing a video to see the if it streams in HD. I have attached my DRM info proof
  5. JanLuck.Pincard
    Jelly Bean Aug 21, 2021
    JanLuck.Pincard , via OnePlus 7T , Aug 21, 2021 :
    Think they are just stalling to keep us quiet 😠 and since the problem is not only occuring for 7T but to a lot of users running Oxygenos11 on other models, It is probably more difficult to find than it looks.
    Read some threads on XDA forum that ppixel users who reverted from Android 12 beta to Android11 olso had it reocuring after Google just fixed it in march or April.
    Guess we just have to be patiënt.
    At least the google play systemchanges are incorperated in the regular security updates, but it is annoying as hell.
    Hope we get the next security update to august or september soon. 😀
    Sam197 likes this.
  6. molydenum
    Cupcake Aug 22, 2021
  7. AndroidManiac
    Ice Cream Sandwich Aug 22, 2021
    AndroidManiac , Aug 22, 2021 :
    That's unfortunate. Did you put any screen protector onto your device? I've read that it's advised to delete your old finger print then create a new finger print in the hope that this is a quick and easy solution. Even if you've got no screen protector, I'd still suggest this possible solution.
    Please try that and advise back please. Good luck and hope that fixed your problem.
  8. molydenum
    molydenum , via OnePlus 7T , Aug 22, 2021 :
    Unfortunately I think it's software issue. When the fingerprint doesn't work, you can't add any as it won't detect the finger to add... And if you reboot when it stop working, the fingerprint option is hidden from the security menu and you have to reboot again and clear cache for it to return...
  9. Mohan Reddy Y V M , via OnePlus 7T Glacier Blue , Aug 22, 2021 :
  10. VShubham410
    Gingerbread Aug 22, 2021
  11. SainathSN
    Eclair Aug 22, 2021
  12. mysky911
    Froyo Aug 22, 2021
  13. Roei.e
    Honeycomb Aug 22, 2021
    tarkzy likes this.
  14. ghostofcain
    Marshmallow Aug 22, 2021
    ghostofcain , Aug 22, 2021 :
    That's not what the SS shows, it shows a user being asked for further information, log files, and deciding to pick a fight instead.
  15. Roei.e
    Roei.e , via OnePlus 7T , Aug 22, 2021 :
    Because I already sent them Oem_log and they said they didn't found anything. And for f*** why the hell do they need log for a problem that occurs on every device. They can take device from their own and check it. Don't be an idiot OnePlus fan
  16. Vikas Sharma 7T
    Vikas Sharma 7T , Aug 22, 2021 :
    That's not what the comment shows, it shows a user is posting his/her experience in the community and a random dude is picking fights with every genuine user.
    Even a 10 year old kid these days can tell they don't require device logs if the problem is occurring in all the devices. Anyway, I'll pretend that I didn't read your comment. Peace ✌️
  17. Bysana!
    Bysana! , via OnePlus 7T Pro , Aug 22, 2021 :
    Thanks for the answer!
    It's not like I really want to update, my phone works fine with me but I still get a popup to update. And I know about all of the issues the update has (or did have) and that's why I'm not sure.
    It's working so why should I.
    But if it's not giving any issues and makes the popup disappear... Fine. So yeah I'm in doubt haha
  18. kãräñ_90564
    kãräñ_90564 , Aug 22, 2021 :
    Haptic feedback strength is significantly reducing in this build. Is anyone facing the same issue?
    NishantCh and Atanu95 like this.
  19. Atanu95
    Froyo Aug 22, 2021
    Atanu95 , via OnePlus 7T , Aug 22, 2021 :
    Yup it's decreasing the feel.
    NishantCh likes this.
  20. sambit1+
    Froyo Aug 22, 2021
    sambit1+ , via OnePlus 7T , Aug 22, 2021 :
    Not working..
    Tried as u said.
