103
OxygenOS 11.0.2.1 for the OnePlus 7T Pro and OnePlus 7T
  1. PoL19
    Gingerbread Jul 28, 2021
    PoL19 , via OnePlus 7T , Jul 28, 2021 :
    For the last two updates, the battery has been unimpressive to say the least. Recently, apps have started to misbehave too. Signal reception isn't up to par. I don't need Android 12. Just fix these lot.
  2. Tmokal
    Honeycomb Jul 28, 2021
  3. Chayan_M
  4. GianJames15
    Froyo Jul 28, 2021
    GianJames15 , via OnePlus 7T Pro , Jul 28, 2021 :
    Why are you all clamoring for this update? It's clear that OOS 10 is still better. Stick/revert to OOS 10 and you're phone will be smooth af. Obviously they messed up OOS 11 that even their latest 9 series with the beastly Snapdragon 888 SoC are still full of bugs/problems so why bother?
    Totsquest and Edward_ like this.
  5. MrDJ83
  6. GianJames15
    Froyo Jul 28, 2021
    My battery usage with heavy fb and messenger usage. Also using mobile data throughout with 2 sims inserted. OOS 11 can't come close to this OOS 10 battery life
  7. S1584800280884
    Cupcake Jul 28, 2021
    S1584800280884 , via OnePlus 7T , Jul 28, 2021 :
    Hi,
    I've been using one plus 7t for a year and the experience is good. But recently I've noticed that the battery doesn't last as it used to be even though I use the phone the same way from the time I picked it. And the brightness goes down for a while and comes back to normal automatically. I feel that after the new system update I'm facing this issue. Can anyone help me to fix this.
    Christian_Schimmell likes this.
  8. DavidMdz
    DavidMdz , Jul 28, 2021 :
    Screenshot_20210728-140115.png When I bought my OP 7T Pro T-Mobile I was afraid because I heard that the updates will take more time to arrive, but apparently now T-Mobile versions are getting better updates
  9. Edward_
    Ice Cream Sandwich Jul 28, 2021
    Edward_ , Jul 28, 2021 :
    I'm sticking with OOS10, but I am getting a little tired of the nagging to download the update.
    Is there a way to patch the security without downloading the whole OS? Or is this the latest security update for OOS10?
    Mr Olo likes this.
  10. Rupankar13
    Totsquest likes this.
  11. Drasm19
    Drasm19 , Jul 28, 2021 :
    Not that I know of.
  12. vquick
    vquick , via OnePlus 7T , Jul 28, 2021 :
    Just checked Android Auto with my car (VW Mk7.5 Golf family) and delay bug is not fixed. Still a ~2 minute delay after connecting phone to car before they recognize each other and Android Auto is usable. Highly annoying.
    With this build and the last, I have no major issues other than this. Battery life is fine, no overheating, although I don't play any games. Actually, my phone does overheat, but only when I accidentally leave it in the sun outside!
  13. PDA59
    Froyo Jul 28, 2021
    PDA59 , via OnePlus 9 Pro , Jul 28, 2021 :
    I just checked on my OP 9 pro India as well as the 7T india .
    A bit of a controversial thing IMO But confirmed.The telephoto lens do not activate if light is low. It uses main sensor. Under well lit condition it again uses telephoto normally!!!
  14. PDA59
    Froyo Jul 28, 2021
  15. PDA59
    Froyo Jul 28, 2021
    Thanks for the heads-up, was using the telephoto as placebo in low light. Damn. In daylight I guess it uses telephoto actual one. But in lowlights it uses the main camera and crops to make it look like a zoom!!!!
    PriyeshPatil and JvdBeemt like this.
  16. JanLuck.Pincard
    Jelly Bean Jul 28, 2021
    JanLuck.Pincard , via OnePlus 7T , Jul 28, 2021 :
    No such problems with my renault scenic model 4 (2018) and rlink-2 version 7.04.166.
    Reacts almost instanly when I plugin the phone.
  17. muhammadkhaleeq
    Eclair Jul 28, 2021
  18. JanLuck.Pincard
    Wow your right in poor light conditions software uses standard lens in stead of telefoto lens.
    Wonder why that is.
    Might be that lens diafragma of telelens is to small to provide enough light on the sensor chip make a decent picture.
    Never checked in in OOS 10 though.
    PDA59 likes this.
  19. zer0se7en
    BeingIncog likes this.
