103
OxygenOS 11.0.2.1 for the OnePlus 7T Pro and OnePlus 7T
  1. JanLuck.Pincard
    Jelly Bean Jul 30, 2021
    JanLuck.Pincard , via OnePlus 7T , Jul 30, 2021 :
    That is the wrong way around. App will switch to normal lens if light conditions are not ok for telefoto lens.
    Try it the other way around so FiRST choose telefoto and zoom to 2x or more and then gradualy block the telefoto lens. If you see your finger comming into the picture then you wil know it uses telefoto lens.
    In low light conditions app will switch to main sensor, since this is larger and has higher resolution so is better able to capture more light.
    As a camera expert explaind to me this is regular behaviorisme and no bug.
    Sounds logical to me.!
    Perit0s_log1 likes this.
  2. Raveen88
    Eclair Jul 30, 2021
    Raveen88 , via OnePlus 7T , Jul 30, 2021 :
    Thanks for the update bro
  3. SainathSN
    Eclair Jul 30, 2021
  4. julaan
    Cupcake Jul 30, 2021
    G_Abinash_Mishra_ySBM likes this.
  5. G_Tanveer_Singh_tTxr , via OnePlus 7T , Jul 30, 2021 :
    Congratulations OnePlus on continuosly disappointed the users in terms of updates/upgrades, especially the OP7 family. This is another useless update where the so called fix for fixing HDR content doesn't work. Network still shows L3 widevine and HDR capabilities as None.
  6. VShubham410
    Gingerbread Jul 30, 2021
  7. G_Tanveer_Singh_tTxr , via OnePlus 7T , Jul 30, 2021 :
    Google paly system should be 1 March 2021. Please go to Settings- About Phone - Android Version- Google Play system update.
    It should check update and let you update to March .
  8. RG_Nov_17
    RG_Nov_17 , via OnePlus 7T , Jul 30, 2021 :
    Mine is February
  9. AbhiMatanhelia
    Eclair Jul 30, 2021
    AbhiMatanhelia , via OnePlus 7T , Jul 30, 2021 :
    Tried it but it shows it is up to date.. funny that I had March update when I previously updated but due to some bugs I factory reset my phone and it downgraded to Feb and still stuck and the widevine downgrade happened suddenly two weeks ago while streaming on prime video. The phone got hanged and restarted itself and boom it is L3 now.
  10. aoyanb
    Froyo Jul 30, 2021
    aoyanb , via OnePlus 8 Pro , Jul 30, 2021 :
    This might help.
  11. AbhiMatanhelia
    Eclair Jul 30, 2021
  12. AndroidManiac
    Ice Cream Sandwich Jul 30, 2021
    AndroidManiac , Jul 30, 2021 :
    Then I'm really really really lucky cause this update did fix my L3 back to L1 with out magic tricks or uninstalling or clearing anything. It just worked as is completely offer the update and that was the first thing I specifically check to verify and it was verified....!!!!
    MadRockstar86 likes this.
  13. ghostofcain
    Marshmallow Jul 30, 2021
    ghostofcain , Jul 30, 2021 :
    You filed the requisit bugs reports, of course?
    Whereas Google have top notch software, but it's the hardware that lets them down.
    Geekbench, and other benchmark apps, are next to useless on any phone as they rarely reflect real world performance.
    I wouldn't sweat over the security levels if I was you, if you're happy with 10, stick with it there are few compelling reasons to update to android 11 and there's potential pitfalls with any update.
    TBH it's a little early to be making definitive statements on battery life, come back in a week and let us know.
    The fix seems to be working for the majority of people, who previously had issues, no doubt the new bug reports you've filed will help them lick it once and for all.
    H1559593663267 likes this.
  14. AbhiMatanhelia
    Eclair Jul 30, 2021
  15. AndroidManiac
    Dazza11 likes this.
  16. aoyanb
    Froyo Jul 30, 2021
  17. VShubham410
    VShubham410 , via OnePlus 7T , Jul 30, 2021 :
    Have tried this several times, reset internal settings of the phone too, but didn't help. Please let me know if anybody gets successful in getting L1 back.
  18. AndroidManiac
  19. JanLuck.Pincard
  20. lucifer_angel
    Honeycomb Jul 30, 2021
    lucifer_angel , via OnePlus 7T Pro , Jul 30, 2021 :
    No luck bro
    Its still using main cam to zoom. After update Camera app is even struggling to focus also on all 3 lenses.
    said:
    I installed GCam just to be sure and everything is working fine on it, it's the OnePlus camera app that's faulty.
    User experience is degrading with every update still OnePlus is not taking any action. Ignorance at highest level.all hopes lost
