103
OxygenOS 11.0.2.1 for the OnePlus 7T Pro and OnePlus 7T
  1. johari1217
    Donut Jul 31, 2021
    johari1217 , via OnePlus 7T , Jul 31, 2021 :
    Why warp charger adaptor cannot function now after latest update... When i use fast charger power bank can fast charging.... Why oneplus
    0P7T user...
    TheBabaYaga likes this.
  2. yadrob1
    Cupcake Jul 31, 2021
    yadrob1 , Jul 31, 2021 :
    Just asking if there's no AOD still in the latest update for OP7T? I am using Beta 5 and was thinking to come back to stable version, so should I or should I not? ( I like AOD and am using it in the beta version.)
  3. asvkbg
    Donut Jul 31, 2021
    asvkbg , via OnePlus 7T Pro , Jul 31, 2021 :
    I know how hdr looks like but its not supported on prime for 7t pro even though it shows L1 in DRM Info. Thats the issue
  4. asvkbg
    Donut Jul 31, 2021
  5. DerNachbar
    Honeycomb Jul 31, 2021
    DerNachbar , via OnePlus 7T Pro , Jul 31, 2021 :
    It's confirmed that AOD will not make it to any 7 series stable version. Forget about AOD at all in stable version. It's not coming. You don't have to wait for it. OnePlus said they're not satisfied and it's not good enough for stable version.
  6. JanLuck.Pincard
    Jelly Bean Jul 31, 2021
  7. Nishant_Ramteke
    Froyo Jul 31, 2021
    Rishi317 and ojivraj like this.
  8. Atanu95
    Froyo Jul 31, 2021
    Atanu95 , via OnePlus 7T , Jul 31, 2021 :
    After updating to new version your device shown L3 & you hard reset it and it automatically change L3 to L1?
    rituraj_dixit and Shiv_Koul like this.
  9. p2p
    Ice Cream Sandwich Jul 31, 2021
    p2p , via OnePlus 7T , Jul 31, 2021 :
    Yes, it is supported.
    Why do you say not?
    Drasm19 and AndroidManiac like this.
  10. Nikhel_Sharma
    Froyo Jul 31, 2021
    Nikhel_Sharma , via OnePlus 7T , Jul 31, 2021 :
    On OS 10, it never gets warm while gaming. I face heating issue only when I use maps for navigation on/off charging for longer duration... Other wise never. That is why I rolled back, on 11 It was getting warm even if I am using it just for calling. Heating means high battery consumption.. so not suitable for me..
    Abhilash995 likes this.
  11. Bithwn
    Dazza11 likes this.
  12. Drasm19
    Drasm19 , Jul 31, 2021 :
  13. vijith leo
    Eclair Jul 31, 2021
    vijith leo , Jul 31, 2021 :
    Bro try clearing app data (worked for me)
  14. stuma01
    Cupcake Aug 1, 2021
    stuma01 , Aug 1, 2021 :
    What about the OnePlus 7 Pro 5G (GM1925)? I'm kinda feeling like the forgotten and neglected middle child here...
  15. Muraliganesh S
    Eclair Aug 1, 2021
  16. asvkbg
    Donut Aug 1, 2021
  17. ani257
    Froyo Aug 1, 2021
    ani257 , Aug 1, 2021 :
    I am newly updated my op7t 10 to 11 hopping all will be well. Fortunately as of now running well.
    As of now a i have seen two bugs.
    Incoming call popup delay.
    Call volume reduced.
    Here is my battery 🔋 states.
  18. Shiv_Koul
    Eclair Aug 1, 2021
    Shiv_Koul , via OnePlus 7T , Aug 1, 2021 :
    Yes it was showing L3 when i had updated from Os 10 to 11 and there were lot of issues till date when this update came and nothing changed i decided to do hard reset.
  19. Ssudarshan
    Cupcake Aug 1, 2021
    Ssudarshan , via OnePlus 7T , Aug 1, 2021 :
    When I play codm connected to my OnePlus buds z the audio frequently pauses it's irritating while playing the game. I tried with other device the buds worked fine but this problem occurs in my OnePlus 7t. Does anyone faces this problem?
  20. Rishi317
    Gingerbread Aug 1, 2021
    Rishi317 , via OnePlus 7T Glacier Blue , Aug 1, 2021 :
    Reset buds z and connect again
