103
OxygenOS 11.0.2.1 for the OnePlus 7T Pro and OnePlus 7T
  1. MarshaLOP
    Gingerbread Aug 1, 2021
  2. usifaa
    Eclair Aug 1, 2021
    DeepakGulve likes this.
  3. A.Jeyasankar
    A.Jeyasankar , Aug 1, 2021 :
    Oxygen OS 10 [e]1f4aa[/e] Rocking performance always..
    I'm downgrade my OP 7T through OOS 11🧐
  4. Anmolkapoor15
    Cupcake Aug 1, 2021
    TheBabaYaga likes this.
  5. Divakar.S
    Donut Aug 1, 2021
  6. Pawan9141
    Cupcake Aug 1, 2021
    Pawan9141 , via OnePlus 7T , Aug 1, 2021 :
    After updating the O's my phone speaker is swining between the header speaker and footer speaker of the phone. One plus pls fix the issue.
  7. Pawan9141
    Cupcake Aug 1, 2021
  8. Gautam1997
    Donut Aug 1, 2021
    A1569634075556 and Deepak1523 like this.
  9. A.Jeyasankar
    First you should download the beta version of OOS 10 and install it. then download OOS 10 stable version of 10.3.8 and install. that's all
    Pawan9141 likes this.
  10. R1568905389297
    Donut Aug 1, 2021
    R@hulc97, Deepak1523 and Gautam1997 like this.
  11. Rameez_khamar
    Donut Aug 1, 2021
  12. Monty1989
    Cupcake Aug 1, 2021
    Rameez_khamar likes this.
  13. usifaa
    Eclair Aug 1, 2021
    usifaa , via OnePlus 7T , Aug 1, 2021 :
    after 2 days of should i update or not today i finally updated from os10.3.7, and here's my initial review..
    - most of the users are facing widevine issue..but mine is still L1(image attached).
    - gallery isn't slow...it loads images quite fast.
    - about the screen refresh rate, i checked it and it is showing 88-89, so i guess that's good.
    - can't say much about the camera as i use gcam more..though will update about cam soon.
    - haven't played any game yet but will play bgmi at night so will update about battery drain and heating soon.
    *installed update directly on os10.3.7 wiped cache... haven't done any factory reset.
    PankajYogi likes this.
  14. WahidFahim
    Eclair Aug 1, 2021
    WahidFahim , via OnePlus 7T , Aug 1, 2021 :
    Display is choppy as hell....feels like 10hz....using different apps feels like a pain....so jittery! Battery backup doesn't seem to improve that much!still have L3...tried doing Factory Reset...nothing worked! And I don't know what will! 😔😔
    chaitanya_m10 and TheBabaYaga like this.
  15. Ionel Malasinc
  16. kãräñ_90564
    Ice Cream Sandwich Aug 1, 2021
    kãräñ_90564 , Aug 1, 2021 :
    I have around 5 thousands high resolution photos and around 40 4k60fps videos and gallery is still loading very slow in my case. Even on OOS10 it was slow, I remember it became slow after the disastrous gallery update on Play store.
    usifaa likes this.
  17. D1600610555193
    Honeycomb Aug 1, 2021
  18. accuphase
    accuphase , Aug 1, 2021 :
  19. AndroidManiac
    AndroidManiac , Aug 1, 2021 :
    Very strange problem indeed cause this latest update fixed this problem for me the other way from L3 back to L1 and the only thing I did was install the update without Netflix installed. Once the update and root next followed by nextlix install and no factory reset - just a dirty flash - can that's how mine was finally fixed.... So it's like while the update corrected the problem for me - the update seems to have caused the complete opposite for others and caused L1 to go to L3 . Don't get that but that seems to be the new trend with this OOS11 update.
    Just my observation...
    Sashi_Kumar likes this.
  20. Tausif.Shaikh007
