103
OxygenOS 11.0.2.1 for the OnePlus 7T Pro and OnePlus 7T
  1. LaInfluenza
    Cupcake Aug 1, 2021
  2. usifaa
    Eclair Aug 1, 2021
    usifaa , via OnePlus 7T , Aug 1, 2021 :
    i have 4500+ photos and some hundred vids it is good for me....same as os10...
  3. user1901
    Froyo Aug 1, 2021
    Pradhyu_17 likes this.
  4. usifaa
    Eclair Aug 1, 2021
    BGMI UPDATE
    - played 3 erangle matches one on #13 and 2 chicken so around 1hr 15 mins with graphics smooth and 90fps..battery drained from 76 to 45 ...n ya also with Bluetooth earphones...
    - when i was done playing phone temp was 37 and room temp was 26
    it is fair enough iguess
    TheBabaYaga, Totsquest and kunu7458 like this.
  5. zFuQian
    Cupcake Aug 1, 2021
  6. D1600610555193
    Honeycomb Aug 1, 2021
  7. ghostofcain
    Marshmallow Aug 1, 2021
    ghostofcain , Aug 1, 2021 :
    It takes at least 3-4 full charge cycles for the OS to adjust to your usage patterns, if it's no better after four days try visiting the pinned battery threads to identify the culprits.
    You've of course waited at least 3-4 full charge cycles for the OS to adapt before reaching this conclusion?
    You'll lose all the Indian specific bloatware, and possibly call recording.
    Yes it is.
  8. ZaidShamsi
    Cupcake Aug 2, 2021
    ZaidShamsi , via OnePlus 7T Pro 5G , Aug 2, 2021 :
    Will this update fix the issue of OnePlus 7T pro "audio is not working on Aptx Adaptive" I bought new earbuds which support Aptx Adaptive but when I switch to aptx adaptive on my mobile audio just doesn't work there's no sound ☹️☹️
  9. Totsquest
    Honeycomb Aug 2, 2021
    Totsquest , via OnePlus 7T Pro , Aug 2, 2021 :
    Great share, thank you....! 👍🏻
  10. LightStar7T
    Eclair Aug 2, 2021
    LightStar7T , via OnePlus 7T , Aug 2, 2021 :
    Hi, i am facing an issue with 4g connectivity in OP7T. Whenever i turn on the mobile data it only shows 3G so i had to switch on the airplane mode and then switch it off in order to get 4G working. Why it is not working from the start is out of my knowledge. Anyone else facing such issue after the update?
  11. E1596960809058
    Froyo Aug 2, 2021
    Gautam1997 likes this.
  12. Gautam1997
    Donut Aug 2, 2021
  13. Gautam1997
    Donut Aug 2, 2021
    E1596960809058 likes this.
  14. numaan@58
    Cupcake Aug 2, 2021
  15. LaInfluenza
    Cupcake Aug 2, 2021
    LaInfluenza , via OnePlus 7T Pro 5G , Aug 2, 2021 :
    This oxygen updater update can I put it in my 7t pro mclaren?
  16. V1599394430527
    Cupcake Aug 2, 2021
  17. mohamednadirkn , via OnePlus 7T Frosted Silver , Aug 2, 2021 :
    I updated through Oxygen Updater, because I haven't got any updates after Oxygen OS 10 TO 11. The update worked. I git the L1 on Netflix, the build number is now showing in the setting, battery life have improved and also the heating is less. But in the setting, the changelog is that of the same uodaet that I got in March. Is there any way to fix it
  18. PankajYogi
    Froyo Aug 2, 2021
    PankajYogi , via OnePlus 7T , Aug 2, 2021 :
    Is it good enough??
    hariskhan95 and Jinen like this.
  19. Totsquest
