103
OxygenOS 11.0.2.1 for the OnePlus 7T Pro and OnePlus 7T
  1. G_siddarth_sreekumar_RGN , via OnePlus 7T , Aug 13, 2021 :
    I face them very regularly. Only when I restart the phone it feels better for a while and again frame rate starts dropping
  2. Robert.Laffan
    Cupcake Aug 13, 2021
  3. kãräñ_90564
    Ice Cream Sandwich Aug 13, 2021
    kãräñ_90564 , Aug 13, 2021 :
    Do you mean refresh rate drop issue?
    Do you remember how it occurs or method of reproducing that issue? Or it occurs on its own suddenly?
    Totsquest likes this.
  4. G_siddarth_sreekumar_RGN , via OnePlus 7T , Aug 13, 2021 :
    Yes refresh rate drop issue. It comes on its own and stays forever. If I restart the phone it feels better for a while and again drops.
  5. theoceaneer
    Froyo Aug 13, 2021
    theoceaneer , via OnePlus 7T , Aug 13, 2021 :
    Good for you. How much time it takes to charge from about 20% to 100% for your phone? It's atleast showing warp charging for you. It's not even showing that on my 7t. It's just plain saying charging. And takes around 1:30 hours to charge from 50 to 100. Sometimes more. I checked the charging current via an app, it only shows it's taking around 1.2 to 1.4 amps max. But in reality, as warp charging, it should take above 5 amps.
  6. kãräñ_90564
    kãräñ_90564 , via OnePlus 7T , Aug 13, 2021 :
    I think you may be facing the issue after closing the screen while YouTube or other apps remains open which runs on refresh rate below 90hz.
    Solution (Not permanent fix) - Rather than restarting your device again and again or going back to settings for switching refresh rate from 90 to 60 then 60 to 90hz.
    I suggest you to atleast once you should try re-opening the YouTube, And play any video on full screen. It will solve the issue but it's not permanent fix. This is a bug which can only be solved by OnePlus developers.
  7. theoceaneer
    Froyo Aug 13, 2021
    My 7t screen is working perfectly. I have updated to 11.0.2.1 and have no issues so far with refresh rate. The only problem I am facing is warp charging. My phone is charging at a slow rate. Tried other OnePlus charger, tried my charger on similar phone, seems like it's the problem with my phone or software, charger and cable is good. Attaching screen refresh rate test screenshot here.
  8. user1901
    Froyo Aug 13, 2021
  9. arunsagarsk
    Gingerbread Aug 13, 2021
    arunsagarsk , via OnePlus 7T , Aug 13, 2021 :
    If u want to check for the refresh rate bug ther is an easy way. Play any video on youtube and lock screen. Keep it like that for approx 5 min. Then unlock phone. Ui should lag like crazy.
  10. arunsagarsk
    If u want to check for the refresh rate bug there is an easy way. Play any video on youtube and lock screen. Keep it like that for approx 5 min. Then unlock phone. Ui should lag like crazy.
    A1580619949542 likes this.
  11. ghostofcain
    Marshmallow Aug 13, 2021
    ghostofcain , Aug 13, 2021 :
    You've tried disabling optimised charging? That seems to help some users
    theoceaneer likes this.
  12. Sandeepsigroha
  13. Sandeepsigroha
  14. BunnyMunnu
    Honeycomb Aug 13, 2021
  15. BunnyMunnu
    BunnyMunnu , via OnePlus 7T , Aug 13, 2021 :
    R u kidding me. Then why the hell I'm getting 60fps stable
  16. theoceaneer
    Froyo Aug 13, 2021
    Yes I have tried that. But didn't make any difference.
  17. theoceaneer
    Froyo Aug 13, 2021
  18. BunnyMunnu
    It took me like 1hr 6 mins to do complete charge i.e 0-100%
    P1597414488486 and theoceaneer like this.
  19. BunnyMunnu
    Not for me bro. I'm getting very fast charging speeds, that too without heating while charging
  20. theoceaneer
    Froyo Aug 13, 2021
    That's perfect. It's not working for me. Guess it's time for me to take it to some ASP to sort this out. I still have the extended warranty till October 21.
