132
OxygenOS 11.0.2.2 for the OnePlus 8 and OnePlus 8 Pro
  1. Zeaiclies
    Honeycomb Jan 12, 2021
    Zeaiclies , via OnePlus 8 , Jan 12, 2021 :
    No I am not using any custom software.
  2. ViperGRM
    Eclair Jan 12, 2021
    ViperGRM , via OnePlus 8 Pro , Jan 12, 2021 :
    That explains why HD/HDR works ok. It should. It's only custom ROMs that will work only in SD.
  3. aritra123
    aritra123 , via OnePlus 8 Glacial Green , Jan 12, 2021 :
    Oxygen os 10 is soo stable than os 11. I am thinking to roll back
  4. ViperGRM
    Eclair Jan 12, 2021
    It sure is. That's exactly why I rolled back. You gain nothing by going to OOS 11 now other than a slightly more pleasing layout and slicker animations. That is subjective still. If they can sort out the bugs and the shocking battery life then I may go back to stock. It's almost unforgivable that a third party developer team who work mostly for free can come up with a battery life that is not far off twice as much compared to OOS 11. This is with the same apps installed and running in the background.
  5. Vipulkalani
    Cupcake Jan 12, 2021
  6. Zeaiclies
  7. aritra123
    Honeycomb Jan 13, 2021
  8. Zeaiclies
  9. aritra123
    Honeycomb Jan 14, 2021
  10. Tee_Eee_Bee
    Jelly Bean Jan 14, 2021
    Tee_Eee_Bee , Jan 14, 2021 :
    Record a call
    You can use your Phone app to record calls and listen to saved recordings.
    Only certain devices and carriers support this feature. You can't record calls in all countries and regions. To record your phone calls:
    • Your device must run Android 9 or higher.
    • Your device must have the Phone app pre-installed and updated to the latest version.
    • You must be in a supported country or region (and IIRC any SIM you use - if using 2 SIMs, then both - must be from that region as well)
    From https://support.google.com/phoneapp/answer/9803950?hl=en
  11. Zeaiclies
    Zeaiclies , via OnePlus 8 , Jan 14, 2021 :
    Yeah it is disabled in North America
  12. Makjaiswal
    Cupcake Jan 14, 2021
  13. aritra123
    Honeycomb Jan 15, 2021
    Zeaiclies likes this.
  14. Zeaiclies
    Zeaiclies , via OnePlus 8 , Jan 15, 2021 :
    Though not an encrypted connection on either app's use. lol
  15. rksanjay90
    Donut Jan 16, 2021
    rksanjay90 , via OnePlus 8 , Jan 16, 2021 :
    Did cache wipe initially battery looked improved but now noticed overnight losing about 10%. Should I roll back to 10?
  16. aritra123
    Honeycomb Jan 16, 2021
  17. aritra123
    Honeycomb Jan 17, 2021
    aritra123 , via OnePlus 8 Glacial Green , Jan 17, 2021 :
    What is the name of this ui???
  18. ViperGRM
    Eclair Jan 19, 2021
