132
OxygenOS 11.0.2.2 for the OnePlus 8 and OnePlus 8 Pro
  1. NickCF
    Froyo Nov 27, 2020
    NickCF , via OnePlus 8 Pro , Nov 27, 2020 :
    You have 2 Sims...Depends where do you live and quality of the signal..
    I mean 6h30 sot is not bad...Depends what are your doing but what do you expect honestly...? 12h sot ? Impossible...
    I have usually 7h 7h30 in heavy use...
    Sometimes less.
  2. Dimi Dimitrov
    Gingerbread Nov 27, 2020
    Dimi Dimitrov , Nov 27, 2020 :
    Thanks for answer.
  3. Corneto
    Froyo Nov 27, 2020
    Corneto , via OnePlus 8 Pro , Nov 27, 2020 :
    Update to 11.1.1 first, then, provided your region has got the update, you'll get option to update to 11.2.2
  4. gmadmax07
    Ice Cream Sandwich Nov 27, 2020
  5. swolfman
    Eclair Nov 27, 2020
    swolfman , Nov 27, 2020 :
    i am on open beta 4 with Europe version phone
    i tried to flash 11.0.1.1 first, but it did not let me - due to lower version issue
    Is there a bypass ? or link to download full OTA 11.0.2.2
    thanks
  6. Rahul6701
    Eclair Nov 27, 2020
  7. Nikoloski
    Eclair Nov 27, 2020
    Nikoloski , Nov 27, 2020 :
    Hi,
    I have a OP8, EU model IN2013.
    But last couple of updates have been AA (for North America) instead of BA (for EU).
    I have had no problems with data loss, but I am worried because im getting wrong versions.
    Does anyone have the same issue or know if this can be a problem?
    Thanks.
  8. Corneto
    Froyo Nov 27, 2020
    Search for a rollback version in the feed... When I was in OB 2 and I wanted to roll back to stable 10, I had to search for a compatible rollback link that was provided in the post with the download link for OB1. Not sure if the same will work being in OB4, but you could try.
  9. kp17
    Donut Nov 27, 2020
  10. barbuvlad91
    Froyo Nov 27, 2020
  11. NickCF
    Froyo Nov 27, 2020
  12. Mudit@22
    Froyo Nov 27, 2020
  13. yooshuffle67
    Donut Nov 27, 2020
  14. swolfman
    Eclair Nov 27, 2020
    I managed to downgrade to Android 10... upgrade to 11.0.1.1 and manualy install the incremental upgrade to 11.0.2.2 - ZIP available to download in forums
    thanks
    Corneto likes this.
  15. stavros67
    Froyo Nov 27, 2020
  16. basspass
    Froyo Nov 27, 2020
    basspass , via OnePlus 8 Pro , Nov 27, 2020 :
    I received the update. If you haven't done so already you should try updating it now.
    Good luck and have a wonderful New year.
  17. German1982
    Froyo Nov 27, 2020
    German1982 , via OnePlus 8 Pro , Nov 27, 2020 :
    No...my issues are not solved. I still having problems to use 5G (not available with Movistar spain) and I can not install Amazon Prime Now either
  18. Sado0og
    Froyo Nov 27, 2020
    Sado0og , Nov 27, 2020 :
    I use vpn for most European ip based
    To get this update for my 8pro
    But it keeps telling me that u r up2date
    11.0.1.1
    How to get the new uodate
