132
OxygenOS 11.0.2.2 for the OnePlus 8 and OnePlus 8 Pro
  1. MrTalon
    Ice Cream Sandwich Nov 29, 2020
  2. Coluc1969
    Eclair Nov 29, 2020
    Coluc1969 , via OnePlus 8 , Nov 29, 2020 :
    Hello, and after the last update you still did not solve the problem with volte and vowifi 5g not even mention It's been a few months since the launch of op 8 🇪🇺 had volte and vowifi disappeared without a trace and 5g is just advertising the rest only well Perhaps it would be better if in the future you were a little more honest with the potential customers I had and other options I chose you still not convinced that I was the most inspired momeny Maybe you can answer me with solutions not just courtesy Thanks
  3. Frostywuff
    Honeycomb Nov 29, 2020
    Frostywuff , via OnePlus 8 , Nov 29, 2020 :
    It just remain at landscape mode, only way to fix it is to hide the grey bar below and it works fine. Hopefully the next update will fix this annoying issue.
  4. Abbas1103
    Froyo Nov 29, 2020
    pas-pas likes this.
  5. doodle_away
    Eclair Nov 29, 2020
  6. Abbas1103
    Froyo Nov 29, 2020
    Abbas1103 , via OnePlus 8 , Nov 29, 2020 :
    Nothing really. My bt is always on and do a lot of multi tasking too. I usually get 7-8.5 hrs but this was out of the world
    pas-pas and Pringles_man like this.
  7. G1603041213834
    Cupcake Nov 29, 2020
  8. Neeraj.ku.yadav
    Froyo Nov 29, 2020
  9. geoxar
    G1603041213834 likes this.
  10. tex87
    Marshmallow Nov 29, 2020
  11. Danix.Chan
  12. U1529088451754
    U1529088451754 , via OnePlus 8 Pro , Nov 29, 2020 :
    Why is OnePlus 8 Pro lasting 7 hours, while OnePlus 8 vanilla can last for 8-10 hours with basically the same battery? Is it the 90Hz mode? It should be an option on the Pro as well. Hell, the Pro is performing worse even on 60 hz...
  13. GaryWall
    Gingerbread Nov 29, 2020
    GaryWall , Nov 29, 2020 :
    The 120 Hz mode is probably the reason why OP8 does better than the Pro. It also explains the better scores for the OP8 compared to the Pro model with the benchmarking apps like Geekbench. Higher refresh rate is not for free!
  14. U1529088451754
    Sure but the OnePlus 8 is still 90hz, so why can't we have that option? I don't think we'll notice any differences while scrolling on 90hz vs 120hz. But 90hz vs 60hz definitely feels smoother.
    sujay89 and shwongdi like this.
  15. Himanshuchamoli
  16. HaroonAkhtar33
  17. snke
  18. U1529088451754
  19. SilentAtkinson
