132
OxygenOS 11.0.2.2 for the OnePlus 8 and OnePlus 8 Pro
  1. Harshil__07
    Gingerbread Dec 5, 2020
    Harshil__07 , Dec 5, 2020 :
    Mine takes a bit time for the icons to appear on home screen while doing so.
    & why does it need accessibility access??
  2. sahilrana
  3. Frostywuff
    Honeycomb Dec 5, 2020
    Frostywuff , via OnePlus 8 , Dec 5, 2020 :
    Using accessibility for double tap to lock screen here.
  4. Harshil__07
    Yeah same here but it crashes sometimes as the accessibility keeps turning off on it's' own.
    And the same thing can be done with allowing access to modify system settings in other lauchers, system accessibility is a big ask.
    Do you know about any other launchers?
  5. Makjaiswal
    Cupcake Dec 5, 2020
  6. Steuuplait
    Froyo Dec 5, 2020
    Steuuplait , Dec 5, 2020 :
    Bonjour,
    Ne pensez vous pas que le fait de mettre des fonds d'écran animés n'est pas une des raisons pour laquelle l'autonomie du téléphone est mauvaise ?
  7. Frostywuff
    Mine didn't crash at all, I turn all of it on.
  8. Harshil__07
    All of it as in??
  9. Frostywuff
  10. roy141
    Eclair Dec 5, 2020
    xxocu, Claudio_G. and MENINBLK like this.
  11. siva nag
    Eclair Dec 5, 2020
  12. Frostywuff
  13. L1607153000584
    Cupcake Dec 5, 2020
  14. S188
    Cupcake Dec 5, 2020
    S188 , via OnePlus 8 Pro , Dec 5, 2020 :
    The update is stable overall on my 8 Pro, but there's a couple of bugs that NEEDS to fixed ASAP OnePlus :
    1- No 5G/VoLTE options. Also the phone keeps switching cellular networks randomly and dropping/missing calls and/or the person can't hear me or I can't hear them until I end the call and try again which is very annoying and disappointing.
    2- Green tint ONLY in low brightness while watching videos or playing games in full screen.
  15. Claudio_G.
    Claudio_G. , via OnePlus 8 Pro , Dec 5, 2020 :
    It's normal. You don't have problem. Under 5h maybe there is something wrong.
  16. geoxar
    geoxar , via OnePlus 8 Pro , Dec 5, 2020 :
    If you configure Nova launcher based on your taste then it looks awesome! Moreover, it offers a bunch of features that OnePlus launcher doesn't. I always use Nova to all my devices, I got used of all the handy features it offers and I find OnePlus launcher very basic.
    I have suggested them to establish a partnership with Nova launcher instead of trying to re-invent the wheel with OnePlus launcher 😉
    If you are in stable OxygenOS11 then you first need to upgrade to OxygenOS11 beta and then downgrade to OxygenOS10 stable by using the correct rollback package for your device provided below: https://forums.oneplus.com/threads/...nd-features-for-the-oneplus-8-series.1274830/
    Keep in mind that the device will be completely wiped and you will lose all your data if you don't make a backup.
    CaptNemo and S188 like this.
  17. itsamit29 likes this.
  18. gornsg
    Eclair Dec 5, 2020
  19. Frostywuff
  20. Shiv_P98
    Cupcake Dec 5, 2020
    Shiv_P98 , Dec 5, 2020 :
    Still not got this update... where can I download it manually? OP site still shows 11.0.1.1 as the latest.
