77
OxygenOS 11.0.3.1 for the OnePlus 7 Pro and OnePlus 7
  1. T1570024183543
    Froyo Sep 11, 2021
    T1570024183543 , via OnePlus 7 , Sep 11, 2021 :
    Me too bro
  2. R.Peter
    Ice Cream Sandwich Sep 11, 2021
    R.Peter , via OnePlus 7 Pro Mirror Gray , Sep 11, 2021 :
    There is no such thing as "battery backup". There's "backup battery", but that's like an external battery, for example a power bank.
    And I understood it, however if you play games or you continuously use the network it will use more battery, naturally. Similarly, if you run faster you'll get hungry faster.
    JNiemi, akks and Artemus like this.
  3. Artemus
    Community Hero 2020 Sep 11, 2021
    Artemus , Sep 11, 2021 :
    Is it just me or do battery graphs like this get infuriating?
  4. R.Peter
    JNiemi, L1569768949303, akks and 2 others like this.
  5. Satrajit Chakraborty
    Honeycomb Sep 11, 2021
    Satrajit Chakraborty , via OnePlus 7 , Sep 11, 2021 :
    So you buy a phone to use it only for calling?
    T1570024183543 and v1kk1 like this.
  6. Satrajit Chakraborty
    You are using a pro model and I am using a different model. So it will be better if you don't provide your opinion. SOT doesn't last for 3 hrs and you provide a solution to uninstall games and social media apps. Bro then for what purpose I'll buy a phone when I'll don't do anything with it? Can't you check the battery consumption by the system and android OS . It's clearly unoptimised. This wasn't the case in the previous builds.
  7. Artemus
    Community Hero 2020 Sep 12, 2021
    Artemus , Sep 12, 2021 :
    Why do you not charge your phone fully? That might be a contributing factor.
    L1569768949303, R.Peter and akks like this.
  8. v1kk1
    Froyo Sep 12, 2021
    v1kk1 , via OnePlus 7 , Sep 12, 2021 :
    I think you are a new kid in this forum.
    If you have ever read previous posts you will know that problems are faced by certain individuals not all, but majority are facing various issues small or big in the A11 updates.
    If you are getting frustrated by other users problems rather than providing a solution, then ignore the posts and continue scrolling.
    V1560165685313 likes this.
  9. akks
    KitKat Sep 12, 2021
    akks , Sep 12, 2021 :
    You can't deduct anything from such ECG like battery graph. You need to fully charge and then discharge it to single digit battery percentage. Otherwise the % of usage simply gets added on. (Android system 56%).It's not depicting the original battery life. And Facebook apps like instagram, whatsapp etc drain a lot of battery. Also if you play games, definitely the battery consumption will be higher too. May be, those aren't yet optimised completely for android 11, hence more battery drain in oos11.
    And the term "battery backup" on a smartphone was introduced by some dumb YouTubers. No smartphone on earth has a backup energy source. Please avoid using it and following videos of such ignorant youtubers.
    Ashok3322, L1569768949303 and R.Peter like this.
  10. Satrajit Chakraborty
    Honeycomb Sep 12, 2021
    Satrajit Chakraborty , via OnePlus 7 , Sep 12, 2021 :
    Actually this is after 2 weeks usage. I already charged some 7 to 8 full charge cycles for a week and then receiving around 2.5 hrs SOT. Using this build almost 2 weeks now so didn't charge it to full cycle anymore.
    Battery graph ss I provided only to have an idea about the battery drain curve which used to be better in the previous builds.
    T1570024183543 likes this.
  11. akks
    KitKat Sep 12, 2021
    That isn't a "curve", that's exactly what I meant. Doesn't depict anything from that ECG
  12. Singhnaman
    Froyo Sep 12, 2021
  13. Rishi_Pisces
    Gingerbread Sep 12, 2021
    Rishi_Pisces , via OnePlus 7 , Sep 12, 2021 :
    Which App did you use?
  14. R.Peter
    Ice Cream Sandwich Sep 12, 2021
    R.Peter , via OnePlus 7 Pro Mirror Gray , Sep 12, 2021 :
    I'm not new here, I'm around for a while. And yeah, if you use the phone continuously that will drain the battery, especially if you play games on the device. That's how things work.
    I'm also on A11 and the phone keeps up for 2 days. But I take the phone off, it isn't always in my hands.
  15. R.Peter
    Obviously no. But if the main problem is battery consumption and it's clear the user plays hours long, guess what may drains the battery?
  16. V1560165685313
    V1560165685313 , via OnePlus 7 , Sep 12, 2021 :
    Only suggestion. Please check battery health by OnePlus diagnosis app. May e your battery life has issue. As we are using from more than 2years
    Singhnaman likes this.
  17. Singhnaman
    Froyo Sep 12, 2021
  18. V1560165685313
  19. Singhnaman
    Froyo Sep 12, 2021
  20. Medullitus
    Froyo Sep 12, 2021
    Medullitus , Sep 12, 2021 :
    Hey. I'm using Op7Pro. Updating it to 11.0.2.1 is fixing the problem. That's all I do.
