78
OxygenOS 11.0.3.1 for the OnePlus 7 Pro and OnePlus 7
  1. flither
    Honeycomb Sep 17, 2021
    flither , Sep 17, 2021 :
    It is quite reliable I think (at least for me). It shows 93% health after almost 2 years of usage, almost the same as Accubattery (94%) and BatteryGuru (also 94%).
    Screen on time is still more than 10 hours usually
  2. vamsikris
    Donut Sep 17, 2021
  3. wickedscav
    Eclair Sep 17, 2021
  4. K1577555224305
  5. POE65
    Gingerbread Sep 17, 2021
    POE65 , via OnePlus 7 , Sep 17, 2021 :
    You can download the app Oxygen Updater....
  6. x_jayreghe_x
    x_jayreghe_x , via OnePlus 7 , Sep 17, 2021 :
    How's your battery health at 94% even after 2 years?
    T1570024183543 likes this.
  7. F_Castro_EICP
    F_Castro_EICP , via OnePlus 7 Pro , Sep 17, 2021 :
    On my 7 Pro, the OnePlus Diagnostic Tool says 81%, since (at least) September 2020 (bought it when was released)!
    And this result by charging according to the recommendations between 95 to 98% of the times.
    I asked OnePlus, precisely that month/year, about it and they said:
    "I would like to inform you that you no need to worry about the battery when its battery health is higher than 75%.
    If your device battery health is higher than 75% then please do not worry, It is normal and If it shows lower than 75% then your device needs replacement of battery."
  8. idiocracy
    Eclair Sep 18, 2021
    idiocracy , Sep 18, 2021 :
    Does not appear like they fixed Google fit tracking issues, had to reboot today.
  9. emiliano.sune
    Eclair Sep 18, 2021
  10. Artemus
    Junior Moderator, Community Hero 2020 Junior Moderator Sep 18, 2021
  11. emiliano.sune
    Eclair Sep 18, 2021
    emiliano.sune , via OnePlus 7 Pro , Sep 18, 2021 :
    Mind elaborating? What firmare would be mismatched, and how exactly?
    My phone is originally a T-Mobile revision that is now on global OOS10 so I don't understand how there can be a firmware mismatch since all the partitions were correctly updated with the new images.
  12. Artemus
    Artemus , Sep 18, 2021 :
    All I know is, the T-Mo variant doesn't work on OOS 11 all that well and is probably due to how it's built. Carrier variants are fickle when it comes to low-level software customization.
    Some people have had success with lowering the resolution to FHD and/or keeping it at 60 Hz.
  13. emiliano.sune
    Eclair Sep 18, 2021
    Lowering the refresh rate causes a blank screen for me so it isn't a solution.
    Flashing the international firmware on the phone should make it the same as the international version, unless there's hidden ROMs that are not being updated - which seems unlikely.
    This is only hurting customers as OnePlus and T-Mobile are playing hot potato on who's responsible and a fix is not being released or even worked on.
  14. Singhnaman
    Gingerbread Sep 18, 2021
  15. Adi_2019
    Ice Cream Sandwich Sep 18, 2021
    Adi_2019 , via OnePlus 7 , Sep 18, 2021 :
    Do you use your phone only to make & receive phone calls? 😏
  16. HRG_Henry
    Froyo Sep 18, 2021
    iulisimo likes this.
  17. Artemus
    Still good, I believe. What version are you on right now?
  18. core25
    Cupcake Sep 18, 2021
  19. V218
    Eclair Sep 18, 2021
    Fredator and Ahsanraza0633 like this.
  20. U1604472686617
    U1604472686617 , Sep 18, 2021 :
    Use the Oxygen Updater app from the Playstore.
    I used it to update to the latest 11.0.3.1 EU update with no issues.
