78
OxygenOS 11.0.3.1 for the OnePlus 7 Pro and OnePlus 7
  1. Medxion007
    Eclair Oct 11, 2021
    Medxion007 , Oct 11, 2021 :
    Yes Swapping the sims does the same. The SIM that got the internet connection active is sometimes offline. Also my 4g connections aren't working anymore even when i setup my UPN settings correctly like it worked before.
  2. akks
    KitKat Oct 11, 2021
    akks , Oct 11, 2021 :
    Try disabling VPN/Private DNS and recheck
  3. Marchelius
    Froyo Oct 11, 2021
    Marchelius , Oct 11, 2021 :
    Check out my posts, I described how to do this before. You must use the MSM Tool and the appropriate firmware file
  4. Jamesjaynt27
    Donut Oct 11, 2021
  5. DakshDoi
    Eclair Oct 11, 2021
    DakshDoi , via OnePlus 7 , Oct 11, 2021 :
    Use MSMDOWNLOADER(available for every versions available for device), search the process in YouTube,
    The software is similar to what service centers use
    Warning Data would be wiped.
    indranujkar likes this.
  6. Artemus
    Community Hero 2020 Oct 11, 2021
    Shailender Sharma and Netsky60 like this.
  7. indranujkar
    Froyo Oct 11, 2021
    indranujkar , Oct 11, 2021 :
    Thanks buddy!
    Fallen in love with OnePlus 7 pro again (with Oxygen OS 10.3.8). It's a shame, how OnePlus destroyed a perfectly capable device by introducing BugPlus software updates.
  8. U1604472686617
    Gingerbread Oct 11, 2021
    U1604472686617 , Oct 11, 2021 :
    The tools, files and process is explained here.
    As previously stated this will wipe your phone so save EVERYTHING you want to keep.
    https://forum.xda-developers.com/t/...0-gm21ba-collection-of-unbrick-tools.3956595/
    Good luck...
  9. martinmuir99
    Eclair Oct 11, 2021
    T1570024183543 likes this.
  10. Sarthak Vishu
    Froyo Oct 12, 2021
  11. Jamesjaynt27
    Donut Oct 12, 2021
    Jamesjaynt27 , via OnePlus 7 Pro , Oct 12, 2021 :
    Ok thanks
    Artemus likes this.
  12. Artemus
    Community Hero 2020 Oct 12, 2021
    Artemus , Oct 12, 2021 :
    What version are you on right now?
  13. Medxion007
    Eclair Oct 12, 2021
    Medxion007 , Oct 12, 2021 :
    VPN was not enabled. I disabled Private DNS and rebooted the devices. Checked my 4g on both sims and even switched between 3g / 4g. But still no 4g connection. Any other suggestions ?
  14. akks
    KitKat Oct 12, 2021
    akks , Oct 12, 2021 :
    Try "reset to default" access point
    Artemus likes this.
  15. Dejvo96
    Donut Oct 12, 2021
  16. gdsingh94
    Jelly Bean Oct 12, 2021
    gdsingh94 , via OnePlus 7 , Oct 12, 2021 :
    Never.. you have to manually update to 11.3.1 and you will lose all your data in the process.. so don't forget to take a backup..
    Artemus likes this.
  17. Netsky60
    Ice Cream Sandwich Oct 12, 2021
    Netsky60 , Oct 12, 2021 :
    Agreed, every SOT are differents, depending of users usages / apps
    Artemus likes this.
  18. Jamesjaynt27
    Donut Oct 12, 2021
    Lucky_Sharma and T1570024183543 like this.
  19. Jamesjaynt27
    Donut Oct 12, 2021
    Lucky_Sharma likes this.
  20. Lucky_Sharma
    Gingerbread Oct 12, 2021
