104
OxygenOS 11.0.3.1 for the OnePlus 7T Pro and OnePlus 7T
  1. gavityonkesh
    Cupcake Sep 5, 2021
    sree1906 likes this.
  2. vedangpandya
    Gingerbread Sep 5, 2021
    vedangpandya , via OnePlus 7T , Sep 5, 2021 :
    It seems it won't come before September End. As you can check previous record. June Security Update provided in August so how can you expect the August Security Update in the beginning of September??😆😆😆
  3. Gohil_Chirag
    Honeycomb Sep 5, 2021
  4. TheBabaYaga
    Froyo Sep 5, 2021
    PriyeshPatil likes this.
  5. unnikrishnan_s
  6. kãräñ_90564
    Ice Cream Sandwich Sep 5, 2021
    kãräñ_90564 , via OnePlus 7T , Sep 5, 2021 :
    Vivo 10k phone at my home has already got August security in mid of August.
    TheBabaYaga, Jinen and vedangpandya like this.
  7. Chand6391
    Chand6391 , via OnePlus 7T Pro , Sep 5, 2021 :
    The update have been paused i think for stable release. I checked all necessary sources but unable to find the update file. I'm Hoping for 12 instead of these fixes.
  8. vedangpandya
    My Xiaomi MI A3 bought for just 13k got August Security Update in the first week of August itself, it was neither flagship nor a midrange. It was a budget device.
    Shame on OnePlus. 7T is a flagship or was a flagship atleast at the time of launch and still by no means cheaper for 3 times the price of MI A3.
    And you guys see no value in older flagships once a new series launched. This isn't OnePlus what we thought of.
    It's better to get a budget phone use it as you like. Get mods custom OS. Play with whatever you want. And you can change it after 2 years. Still won't break your wallet instead of buying a costly elephant and waste your time maintaing it with bugs.
  9. BeingIncog
    Nougat Sep 5, 2021
    BeingIncog , Sep 5, 2021 :
    A12 will come next year.
    Pratim_Das_Gupta likes this.
  10. abhishekislam
    Donut Sep 5, 2021
  11. arunsagarsk
    arunsagarsk , via OnePlus 7T , Sep 5, 2021 :
    For overall system fluidity, i would say 11, but for gaming i would say its better to stick with 10
  12. Sam197
    Jelly Bean Sep 5, 2021
    Sam197 , via OnePlus 7T , Sep 5, 2021 :
    Sure you can install it,but I think you would miss red cable, call recording and network bands features.
    A friendly advice,if you decide to install let make sure you do factory reset couple times but backup your data, pictures and everything.
  13. BeingIncog
    Nougat Sep 5, 2021
    no, call recording is dependent on SIM...
  14. Oksygen
    Oksygen , via OnePlus 7T , Sep 5, 2021 :
    Checked all sources?
    Why is the file on Oxygen Updater then???
  15. kãräñ_90564
    I am currently on v11.0.2.1. I have recently installed bgmi on OOS11, I have seen some flaws but I am not sure whether its fault from KRAFTON, Inc. or from OnePlus. When I installed it and run it, it doesn't turn on gaming mode by default because it recognises bgmi as an app instead of game. So, after installing it first you have to manually turn on gaming mode on OOS11.
    And second flaw is that the Ping is always high on sim 1 and above 200ms which makes game unplayable. Again I am not sure whether its fault from service provider or KRAFTON, Inc.
    And talking about performance, I am not facing any performance issue and device temperature is also normal about 36 to 40°C in my case.
    Hope it helps.
  16. Dikran666
  17. Nafice1
    Eclair Sep 5, 2021
    Nafice1 , via OnePlus 7T Pro , Sep 5, 2021 :
    @ ABDUL B. OnePlus 7t pro EU don't get latest update even after 6 days of release, what happened to the update is it rolled back due to bugs? Or any other good reason please explain.
    Thank you.
    BR.
  18. BeingIncog
    Nougat Sep 5, 2021
    can't you read EU will follow soon.
  19. bhaskararao.m
    Froyo Sep 5, 2021
