104
OxygenOS 11.0.3.1 for the OnePlus 7T Pro and OnePlus 7T
  1. G_Tanveer_Singh_tTxr , via OnePlus 7T , Aug 31, 2021 :
    I know based on the last the two updates of v11. I am really hopeful that this new update is bug free. But the last two OTA for 7T is nothing less than mediocre updates.
    Being n a fan of OnePlus and using it since the days of 3T, the experience has degraded with the v11 update.
    #41
  2. arunsagarsk
    Gingerbread Aug 31, 2021
    arunsagarsk , via OnePlus 7T , Aug 31, 2021 :
    Thanks for pointing it out mate. Much appreciated.
    #42
  3. KushalBhoopalam
    Cupcake Aug 31, 2021
    #43
  4. JanLuck.Pincard
    Jelly Bean Aug 31, 2021
    JanLuck.Pincard , via OnePlus 7T , Aug 31, 2021 :
    Hey,
    Are you someone with a working google play-system security update ( august 1 )
    Or did it get that date on the 11.0.3.1 patch.
    And why did you make the default kernel data unreadable ?? No personal info there as far as I know
    #44
    SachinDhavle likes this.
  5. Ankit_Pathan
    Froyo Aug 31, 2021
    #45
    Naveen_chintala likes this.
  6. R1626096977148
    Donut Aug 31, 2021
    #46
    TusharJhorar and kumarsaurav11 like this.
  7. Nitin Shetye
    Froyo Aug 31, 2021
    Nitin Shetye , via OnePlus 7T , Aug 31, 2021 :
    If incase u update than please do a factory reset after updating, it will work fine
    #47
  8. kãräñ_90564
    Ice Cream Sandwich Aug 31, 2021
    #48
    Krishna.doc and Totsquest like this.
  9. p2p
    p2p , via OnePlus 7T , Aug 31, 2021 :
    Widevine was fixed in 11.0.2.1 build.
    If you still have problems with it you should open a thread in feedback section.
    #49
    Atanu95, AndroidManiac and AzureB1te like this.
  10. VShubham410
    VShubham410 , via OnePlus 7T , Aug 31, 2021 :
    No, it wasn't fixed for most users.
    #50
  11. D1600610555193
    Honeycomb Aug 31, 2021
    #51
    ermanisharma7 likes this.
  12. #52
    Sheppards and AzureB1te like this.
  13. D1600610555193
    #53
  14. D1600610555193
    #54
  15. p2p
    Yes it was.
    Anyway, for users that still have that issue the only option is open a thread in feedback section.
    #55
  16. zuber.
    zuber. , via OnePlus 7T , Aug 31, 2021 :
    My phone has many bugs from previous update of os11 like locking and unlocking sound bug which are not resolved still yet. Kindly fix these bugs
    #56
  17. zer0se7en
    zer0se7en , via OnePlus 7T , Aug 31, 2021 :
    There are so many posts with diffrent procedures of fixing it while on 11.0.2.1. Look for them and try which will work for you.
    #57
  18. ashudev360
    #58
    vedangpandya, us4ak and TheBabaYaga like this.
  19. VShubham410
    I've done everything and it still the same.
    #59
    DeepakGulve and Atanu95 like this.
  20. TheBabaYaga
    Froyo Aug 31, 2021
    TheBabaYaga , via OnePlus 7T , Aug 31, 2021 :
    Well i genuinely dont care about AOD idk why people are mad behind it, anyway its a battery draining feature which you are never going to use. I just hope we get better battery, i got to use this device for like 4 years more!! 😂
    Anyway newer and expensive phones are not worth it. The bigger the price tag lower the value you are getting! So stick with 7t replace battery after couple of years and you are still good to go!
    #60
