102
OxygenOS 11.0.3.1 for the OnePlus 7T Pro and OnePlus 7T
  1. Dikran666
    Gingerbread Sep 9, 2021
    Dikran666 , Sep 9, 2021 :
    Well, if he replied to us, I'd stop tagging him! 😉
  2. BeingIncog
    Nougat Sep 9, 2021
    BeingIncog , Sep 9, 2021 :
    why would he? first understand what does the first post mean! it is been like that for years... it's not new. also what is not new that users will not read or understand the first post.
  3. Intunerikuss and VitalieS like this.
  4. Dikran666
    Well do forgive me, I've only been a OnePlus user for around a year, and I heard so many good things about OnePlus, like for example, they listen and interact with their users, witch is why I bought a OnePlus in the first place, so either they've changed or I've been lied to. Maybe a bit of both? IDK! 🤔
    (I'm being truthful here, so this is not a joke)
  5. Gohil_Chirag
    Honeycomb Sep 9, 2021
    Gohil_Chirag , via OnePlus 7T , Sep 9, 2021 :
    So sad
  6. Rachitshah1201
  7. Sam197
    Jelly Bean Sep 9, 2021
    Sam197 , via OnePlus 7T , Sep 9, 2021 :
    Can you do factory reset for couple times
    Totsquest likes this.
  8. Rachitshah1201
    Kaminatron likes this.
  9. Sam197
    Usually factory reset does the trick
    Did you update from A10 or previous version of A11
  10. Rachitshah1201
  11. Sam197
  12. Rachitshah1201
  13. Rachitshah1201
  14. Linkin1994
  15. Rocky912
    Cupcake Sep 9, 2021
  16. Sam197
  17. JanLuck.Pincard
    JanLuck.Pincard , via OnePlus 7T , Sep 9, 2021 :
    Then your guess is wrong.
    If a change of the update is necessary due to findings during the rollout, it becomes a NEW update.
    So even if so you, would get that new one again faster via Oxygen updater.
    So the choices are the same.
    Only the risk of having to do an extra update is slightly larger 😀
    If you wait for OTA you might skip a halted/retracted one.
    Totsquest and ghostofcain like this.
  18. JanLuck.Pincard
    You might be truthfull, but certainly not patient 😀
  19. tyagishobhitdl
    Eclair Sep 9, 2021
  20. JanLuck.Pincard
    JanLuck.Pincard , Sep 9, 2021 :
    On the google play-system security update issue did the check on the rest of the modules.
    I found 2 mainline apks that have a changed version number since my previous check
    com.google.mainline.telemetry versionCode:302200201
    com.google.android.modulemetadata versionCode:302200806
    This probably is as expected since these were mentioned in the security bulletins for the month we missed.
    We have not got the September update that was released 2 days ago.
    Google Play system updates
    The following issues are included in Project Mainline components.
    Component CVE
    Media Codecs CVE-2021-0690
    lets hope we are now able to do the regular manual update for it in the coming week.
    If it fails again I suspect that we do not get the google play-system updates direct from Google as it is supposed to work but via a Oneplus path.
    That would make me a unhappy customer.
