83
OxygenOS 11.0.3.1 for the OnePlus 7T Pro and OnePlus 7T
  1. G_Ankit_kumar_Raj_heQE
    Eclair Sep 15, 2021 at 7:19 AM
  2. zer0se7en
    Ice Cream Sandwich Sep 15, 2021 at 8:18 AM
    zer0se7en , via OnePlus 7T , Sep 15, 2021 at 8:18 AM :
    Adjust it. If features on the display settings are not enough for you then go to developer options / Drawing / Smallest width. Adjusted mine to 419dp.
    Oneplus 9T likes this.
  3. Ameya@op
    Cupcake Sep 15, 2021 at 8:23 AM
    Ameya@op , via OnePlus 7T Pro Haze Blue , Sep 15, 2021 at 8:23 AM :
    Hi, i am facing this unique issue. Whenever i receive a call when the phone is in pocket while connected to bluetooth headset, the screen gets turned on and the call gets cut or muted or put on hold and so on. Anyone here facing this problem and what can i do to solve this problem ?Would Appreciate ur response.
  4. xpranavkothari
    Gingerbread Sep 15, 2021 at 8:24 AM
    xpranavkothari , via OnePlus 7T , Sep 15, 2021 at 8:24 AM :
    Oh. Mine is 411, I had reduced the display scale to lowest. but still the UI is too much over sized.
  5. zer0se7en
    Ice Cream Sandwich Sep 15, 2021 at 8:33 AM
    zer0se7en , via OnePlus Community App , Sep 15, 2021 at 8:33 AM :
    If you are using OnePlus Launcher, go to its settings. On Homescreen Layout you can adjust Icon size and Grids.
    On Smallest Width, make it higher than 411 to make the UI look smaller.
  6. xpranavkothari
    Gingerbread Sep 15, 2021 at 8:34 AM
  7. kãräñ_90564
    Ice Cream Sandwich Sep 15, 2021 at 8:37 AM
    kãräñ_90564 , via OnePlus 7T , Sep 15, 2021 at 8:37 AM :
    Oneplus is currently suffering from shortage of staff due to pandemic as I asked the reason for the delay in updates that too with bugs.
    OOS 12 is the last hope.
    P1582980766713 likes this.
  8. h1ghland3r
    Froyo Sep 15, 2021 at 8:38 AM
    Totsquest likes this.
  9. xpranavkothari
    Gingerbread Sep 15, 2021 at 8:38 AM
    Sheikafsar likes this.
  10. kãräñ_90564
    Ice Cream Sandwich Sep 15, 2021 at 8:40 AM
  11. zer0se7en
    Ice Cream Sandwich Sep 15, 2021 at 8:41 AM
    zer0se7en , via OnePlus 7T , Sep 15, 2021 at 8:41 AM :
    Actually some users likes what you don't like. The OS is super customizable already for us to get what suits our tastes.
    Have you experienced using pure stock Android? It lacks all these customizations. You'll definitely get bored. Good thing Google is now copying some customizations from OxygenOS and OneUI.
    Dazza11 and xpranavkothari like this.
  12. zer0se7en
    Ice Cream Sandwich Sep 15, 2021 at 8:45 AM
    zer0se7en , via OnePlus 7T , Sep 15, 2021 at 8:45 AM :
    It will get better by the day but will still occasionally comes back. The workaround is enabling lift to wake and also holding the top of the screen first to wake up the sensors before lifting your device. Then tap to wake will work again.
  13. xpranavkothari
    Gingerbread Sep 15, 2021 at 8:48 AM
    xpranavkothari , via OnePlus 7T , Sep 15, 2021 at 8:48 AM :
    That's something I have noted 👍 the stock is far worst than what iOS offers.
    Looking at these, I really feel sometimes the keypad phones were the best lol. 😂
    TheBabaYaga likes this.
  14. xpranavkothari
    Gingerbread Sep 15, 2021 at 8:49 AM
    xpranavkothari , via OnePlus 7T , Sep 15, 2021 at 8:49 AM :
    Ok will try this. And yeah thanks for dp workaround. Trial and error in progress 😬
    zer0se7en likes this.
  15. djtiestoja
    Gingerbread Sep 15, 2021 at 9:42 AM
  16. entho004
    Cupcake Sep 15, 2021 at 9:42 AM
  17. P1582980766713
    Eclair Sep 15, 2021 at 9:58 AM
  18. D1600610555193
    Honeycomb Sep 15, 2021 at 10:00 AM
  19. X1592422926752
    Cupcake Sep 15, 2021 at 10:37 AM
  20. p2p
    Ice Cream Sandwich Sep 15, 2021 at 10:45 AM
    p2p , via OnePlus 7T , Sep 15, 2021 at 10:45 AM :
    Sometimes.
    When it happens what I do is swipe the hand over the proximity sensor and the ambient display goes on.
