100
OxygenOS 11.0.3.1 for the OnePlus 7T Pro and OnePlus 7T
  1. tepetidis kostas
    Gingerbread Sep 17, 2021
    tepetidis kostas , via OnePlus 7T , Sep 17, 2021 :
    Yes, I know, but I would like to update the smartphone officially through the menu.
  2. zer0se7en
    Ice Cream Sandwich Sep 17, 2021
    zer0se7en , via OnePlus 7T , Sep 17, 2021 :
    Then be patient and wait. You can also try rebooting your device. This sometimes trigger the detection of any updates available.
  3. A.Jeyasankar
  4. zer0se7en
    No. It should always be upside down. Also make sure the cloth of your pocket is not so thin. If it is your skin inside that pocket will trigger double tapping your screen because of the friction. Especially when sweaty even for a bit.
    AntonioTC likes this.
  5. A.Jeyasankar
    A.Jeyasankar , Sep 17, 2021 :
    what is your current version
  6. increatul
    Donut Sep 17, 2021
  7. A.Jeyasankar
    I'm in india 10.3.8 it's a very good
    increatul likes this.
  8. uthay27g
    Cupcake Sep 17, 2021
    uthay27g , Sep 17, 2021 :
    I suggest not to update the phone. Android phones are best when you use the pre installed version. I have read many negative feedback from users regarding oxygen os 11. They make ur phone slower, hotter, drain your battery faster and finally make you buy the new oneplus.
    If you want to install, it is a gamble. Your phone may be better or be worst or the same. There is no guarantee your phone will work properly after the update. Incase the update is worse, will oneplus giv you a new phone or what else will they do? They only ignore you.
  9. zer0se7en
    How would you know if better or worse if you don't try? Just like me, many are also having a good experience with the update. Better not decide for anyone.
    Besides, it's an update. Even Apple will ignore you if you are just complaining about the update and not a factory defect. It's always different for all users. We all use our devices differently.
    uthay27g and accuphase like this.
  10. A.Jeyasankar
    A.Jeyasankar , via OnePlus 7T , Sep 17, 2021 :
    Haha after that never buy OnePlus phone😁😁😁😁😂🤣😂
  11. padd046
  12. D1600610555193
    Honeycomb Sep 17, 2021
  13. JanLuck.Pincard
    Jelly Bean Sep 17, 2021
    padd046 likes this.
  14. D1600610555193
  15. BalazsNemeth
    Froyo Sep 17, 2021
  16. A.Jeyasankar
    Gingerbread Sep 18, 2021
  17. Sam197
    Jelly Bean Sep 18, 2021
    A.Jeyasankar likes this.
  18. A.Jeyasankar
    A.Jeyasankar , via OnePlus 7T , Sep 18, 2021 :
    A11 bro
  19. Sam197
  20. DrKTM1+7t
    DrKTM1+7t , via OnePlus 7T , Sep 18, 2021 :
    Issues after the update
    1. Battery heating up after 5 min of usage
    2. Screen on time is below 4 hours even in normal use
    3. System lags as its refresh rate is 10hz (currently on 90hz)
    4. Camera quality reduced
    5. Network speed reduced
    6. Bluetooth connection drops quality
