104
OxygenOS 11.0.3.1 for the OnePlus 7T Pro and OnePlus 7T
  1. increatul
    Eclair Oct 2, 2021
  2. H1574595288911
    Eclair Oct 2, 2021
    increatul likes this.
  3. zer0se7en
    Ice Cream Sandwich Oct 2, 2021
    zer0se7en , via OnePlus 7T , Oct 2, 2021 :
    By testing and getting opinions from other places on the web. This has proven that OnePlus was not the main culprit about battery drains. They are just contributors because they did not anticipate Google to have problems from their own app which is integrated within their OxygenOS.
    Atleast we found a workaround. Also thanks to those other who confirmed it.
    kryolyt likes this.
  4. Jamy23
    OnePlus Bug Hunter Staff Member Oct 2, 2021
    Jamy23 , Oct 2, 2021 :
    We have responded to your concern via personal conversation, please check for the same and let us know if it's working fine.
    Regards,
    Jamy
  5. Jamy23
     We understand your concern, would like to check this further and have got in touch with you via personal conversation for more details.
    Regards,
    Jamy
  6. Jamy23
     For analyzing this better we would need more details to get this sorted out at the earliest. We have dropped you a personal message and would request you to respond to the same.
    Regards,
    Jamy
  7. Jamy23
     In order to get this sorted for you, please help us with the device and Oxygen OS version you're referring to via direct message. Looking forward to your response! 
    Regards,
    Jamy
  8. Jamy23
    Regards,
    Jamy
  9. zer0se7en
    zer0se7en , Oct 2, 2021 :
    Same here EU rom. Still getting 7-8hrs max SoT with regular usage and 5-6hrs Sot with a bit of heavy usage on my almost 2yr old 7T.
  10. xpranavkothari
    Gingerbread Oct 2, 2021
    xpranavkothari , via OnePlus 7T , Oct 2, 2021 :
    Then OnePlus needs to deliver EU builds to IN region. 🤔
  11. increatul
    Eclair Oct 2, 2021
    increatul , via OnePlus 7T Pro , Oct 2, 2021 :
    So should I update now to this 'good' EU stable version?
    The only problem is that I am still on OOS 10 and I don't have time to factory reset and other stuff...so it should work from OTA update perfectly.
  12. Sam197
    Jelly Bean Oct 2, 2021
    Sam197 , Oct 2, 2021 :
    Download the full update
  13. increatul
    Eclair Oct 2, 2021
  14. Sam197
    Download the full update,reset the phone shouldn't take long.
  15. zer0se7en
    Or try the EU rom. I actually came from Global rom then tried out EU rom. I didn't even needed to wipe clean. I just made a backup just in case.
    Make a backup first then flash EU full update. Try not wiping first. If something seems not to work right try clearing cache on recovery mode. If still not satisfied then you can try full wiping. Atleast you already have a backup.
    I remembered going from Global to EU I didn't even do a clean wipe. Still haven't til now. Up to you if whichever suits you best.
    I'm not even living in EU by the way. I'm from the Philippines yet EU rom works great.
  16. increatul
    Eclair Oct 2, 2021
    But how do I know which is the EU version ? (I live in the EU)
    Aa, ok, I see at the beginning of the thread. But I still don't know where to download it, as a single file, outside the system update.
  17. Sam197
    Have you got a notification in your phone
  18. increatul
    Eclair Oct 2, 2021
    increatul , Oct 2, 2021 :
    Yes, I can see it in system updates.
    Ok, a different question: Where can I find OOS 10.0.14.HD01BA if I want to go back to android 10?
  19. Sam197
    You can get it from XDA developers website.
  20. increatul
    Eclair Oct 2, 2021
