80
OxygenOS 11.0.3.3 for the OnePlus 8 and OnePlus 8 Pro
  1. U1529088451754
    Honeycomb Jan 11, 2021
    U1529088451754 , via OnePlus 8 Pro , Jan 11, 2021 :
    No update. This is just laughable.
  2. VIVEK.KR
    Eclair Jan 11, 2021
  3. Pwalraven30
    Gingerbread Jan 11, 2021
    Pwalraven30 , Jan 11, 2021 :
    1 thing is sure my next device won't be a OnePlus anymore, greenish tint still no fixed. Youtube problem, not Stable Android. Time to leave OnePlus
  4. U1529088451754
    Friendly reminder that the next Galaxy phones will be announced in a few days :).. Samsung is also beating Oneplus with 3 years worth of software updates. 5 years with iPhone.
    Alejandrofdez343 likes this.
  5. Z1602127870357
    Cupcake Jan 11, 2021
  6. mohitkmr28
    Eclair Jan 11, 2021
  7. x01
    Donut Jan 11, 2021
    RuuksterRules and DPL900 like this.
  8. HetSalaaa
    Eclair Jan 11, 2021
    Shadow120503 likes this.
  9. Harshil__07
    Harshil__07 , Jan 11, 2021 :
    What about people having issues with 5Ghz wifi and it's inconsistency?? Any solution for that??
    AhnafShahriar likes this.
  10. Unknown1plus
    F_German_Hess_eCme likes this.
  11. GaryWall
    GaryWall , Jan 11, 2021 :
    Did you get 11.0.3.3 for Europe?
  12. DPL900
    Froyo Jan 11, 2021
    DPL900 , Jan 11, 2021 :
    So delete from the page and buy samsung or iphone ...
  13. U1529088451754
  14. Harshil__07
    Can you share the app usage and which launcher are you using?
  15. Harshil__07
    Do you have any issues with 5ghz wifi in your 8 pro??
  16. Dimi Dimitrov
    Dimi Dimitrov , Jan 11, 2021 :
    Not all,have some user without major problem.
  17. mario_luigi
    Jelly Bean Jan 11, 2021
  18. Dimi Dimitrov
    Good news.
    Which country are you from?
  19. ABHIACF
    Froyo Jan 11, 2021
  20. Swejuggalo
    OnePlus 9 Series Expert Community Expert Jan 11, 2021
    Swejuggalo , via OnePlus 8 Pro Ultramarine Blue , Jan 11, 2021 :
    Some get better results if changing channel.
    Some routers get a type of conflict if AX (wifi6) is enabled in the router (disabled solves it).
    Some router that have WPA3 can get better function of using WPA3 instead of WPA2 (several cases confirmed here - apperently my router is one of the affected but I always used WPA3. Also confirmed as a solution on new gen Google WiFi mesh system).
    Some cases of router being set to wrong region (setting it to the correct one solved it).
    Some cases of issues with Smart Connect (disable it and use 2 different SSID instead helps)
    Some cases that don't have WPA2 can possibly benefit from WPA/WPA2 mode instead of just WPA2.
    I've read about these issues on SD865 equipped Samsungs before they switched to 11. At that time they seemed to have about the same issues, same walkarounds and solutions. Sounds more like a Qualcomm driver issue or modem issue.
