98
OxygenOS 11.0.3.4 for the OnePlus 8T
  1. chittela_vamsi
    Gingerbread Nov 5, 2020
    chittela_vamsi , via OnePlus 8T , Nov 5, 2020 :
    If your priority is not the camera then you can join 8T family . My brother had OnePlus 7t and takes amazing pictures when compared to OnePlus 8t. Except night mode improvement, OnePlus 7t is better in terms of camera.
    Cichy3000 and Safu_kp like this.
  2. Nakuul
    Cupcake Nov 5, 2020
    Safu_kp likes this.
  3. Xpress0
    B1600695015471 likes this.
  4. O1603952704701
    Donut Nov 5, 2020
    Safu_kp likes this.
  5. MarHoury
    Cupcake Nov 5, 2020
  6. Ashfak_k
    Donut Nov 5, 2020
    Ashfak_k , via OnePlus 8T , Nov 5, 2020 :
    Even I'm using the 8T but I'm not facing any battery issues. Screen on time is really good & standby time is also great. Only 2-3% battery drain in standby mode during the night when the phone is idle. Get your phone replaced/checked if you facing battery issues. ✌🏻
    Y1603743008207 likes this.
  7. MoshiurBD
    Froyo Nov 5, 2020
  8. Nitingup00
    Eclair Nov 5, 2020
    Nitingup00 , via OnePlus 8 Pro , Nov 5, 2020 :
    Give the update for One Plus 8 pro. It is stuck with 11 update with a lot of bugs. Such a poor company. Hate One plus from the bottom of my heart👎🏻👎🏻
  9. SultanaDaaku
    Honeycomb Nov 5, 2020
  10. SultanaDaaku
    SultanaDaaku , via OnePlus 8T , Nov 5, 2020 :
    Which apps exactly?
  11. SultanaDaaku
    120Hz display will consume battery it is pretty evident. If SOT is above 5 hours it is a good battery backup. Try these it will help your battery last longer.
    1. Change you refresh rate to 60 Hz. SOT lasts for more than 7 hours on this. And if you enable battery saver functionality during less of heavy app usage it lasts for more than 8 hours. Tried and tested.
    2. While on 120Hz enable battery saver whenever you are using normal apps like whatsapp or instagram. Battery saver does not affect the refresh rate as such and it does a pretty good job in saving battery. SOT lasts for around 6-6.5 hours in this.
    Let me know if it works out for you as well.
  12. C1603243845685
    Cupcake Nov 5, 2020
    Pramod_Kushwaha likes this.
  13. neroleptic
  14. neroleptic
    Ghaazee and legitoneplususer like this.
  15. Vinay_Vish007
    Froyo Nov 5, 2020
  16. Xawoger , via OnePlus 8T Lunar Silver , Nov 5, 2020 :
    If you are so worried than you should do a factory reset and restore backup.
  17. derLenno
    The Lab - OnePlus 6 Reviewer Nov 5, 2020
  18. Madrigal1993 , via OnePlus Community App , Nov 5, 2020 :
    I can't even get my 8T phone to even pull the update for 11.0.3.4. I'm still running 11.0.1.3 and it's starting to get frustrating since ive constantly checked everyday to see if I can get it.
