71
OxygenOS 11.0.4.1 for the OnePlus 7 Pro and OnePlus 7
  1. kamien8
    Cupcake Nov 18, 2021
    kamien8 , Nov 18, 2021 :
    Hello,
    I've recently bought pre-owned Chinese version of OP7TPro. There is OOS 11.0.3.1.HD01BA. As I can see, the symbol referes to the European version of OOS. Keeping in mind the fact, it is Chinese version of the phone (with I don't know why EU system), can I safely upgrade to European 11.0.4.1?
    I was told that I should install the update manually rather than using the app. Do you know where to find any tutorial how to safely get it done?
  2. U1604472686617
    Gingerbread Nov 19, 2021
    U1604472686617 , Nov 19, 2021 :
    Check this link out it should help you.
    Backup EVERYTHING as your phone will be wiped and the boot loader will be locked again as phone reverts to stock...
    https://forum.xda-developers.com/t/...l-to-restore-your-device-to-oxygenos.4002909/
  3. Sanket_Shivgan
    srijan kanwal and d.a.gribov like this.
  4. U1604472686617
    Use the Oxygen Updater App from the Playstore...
    Deactivated User likes this.
  5. THEHARDIK
    THEHARDIK , via OnePlus 7 , Nov 19, 2021 :
    Nor did I. I suggest you to wait only. It is not a good update as you have read the threads above. Or if you want it anyway.. then updater apps are available.
  6. Netsky60
    Ice Cream Sandwich Nov 19, 2021
    Netsky60 , Nov 19, 2021 :
    the EU version is very good, my battery is better than ever (2 days use with one charge).
    K1577555224305 and THEHARDIK like this.
  7. THEHARDIK
    That's great! So you have downloaded manually with updater app?
    K1577555224305 likes this.
  8. AaronLobo
    AaronLobo , via OnePlus 7 Pro , Nov 19, 2021 :
    Is it just me or anyone else using YT MUSIC PREMIUM has this issue of not being able to see the album art in notification panel when app is minimised. It's not a phone issue but confirming anyone else facing the same?
    Attached is screenshot.
    Also seems to work fine on other apps like Spotify, Gaana, etc.
  9. K1559682341545
    Eclair Nov 19, 2021
    hthan2009 likes this.
  10. C.H.A.R.L.E.S
    Honeycomb Nov 19, 2021
    C.H.A.R.L.E.S , via OnePlus 7 Pro , Nov 19, 2021 :
    Can you pull down notification panel fully and check it again?
  11. AaronLobo
  12. Skydiver
    Community Hero 2020 Nov 19, 2021
    Skydiver , via OnePlus 7T , Nov 19, 2021 :
    What I find quite incredible is that from a small bug makes its appearance, it is the end of the world!
    People aren't even trying to find a solution to their problem on their own, no!
    They write a post to claim to the whole Community that OnePlus smartphones are crap , that OnePlus is a Crap company
    In short, it's really painful. I reassure those who might call me a Fanboy, it was exactly the same with htc smartphones that I had from the HTC HERO to the U11.
    Exactly the same behavior and it annoyed me as much.
    Pawcio62432 and Deactivated User like this.
  13. C.H.A.R.L.E.S
  14. AaronLobo
  15. ifkdui93
    Gingerbread Nov 20, 2021
    ifkdui93 , via OnePlus 7 Pro , Nov 20, 2021 :
    After updating to android 11 WhatsApp backup takes too long to upload to Google drive, never had any issues on android 10.
    I clean installed this version but still it doesn't work.
    Any fix?
    Tobi 97 likes this.
  16. Adi_2019
    Ice Cream Sandwich Nov 20, 2021
    Adi_2019 , via OnePlus 7 , Nov 20, 2021 :
    Small bug, large bug, a mistake or a blunder, people don't want bugs. But bugs be like, " I AM INEVITABLE". So, people gotta complain whether it's OP, HTC, or whatever. They bought a premium flagship device because they thought it will stay premium it's whole lifetime. And there are problems which are impossible to solve from user's end such as Widevine issue, UI issue, delays, slow processing, etc. Crap or not, oxygen os to color os shift is not something that people are ready to welcome. Doesn't matter if someone agrees or disagrees but the truth is oxygen os 11 has been worse as compared to 10.
    Tobi 97 and K1577555224305 like this.
  17. Adi_2019
    Yes I faced that too. Use a third party file manager such as solid file explorer or connect your device to a PC and copy paste WhatsApp folder from internal storage to PC. Uninstall WhatsApp (don't keep left over data from from WhatsApp if a check box appears). Paste WhatsApp folder in Android/media/com.whatsapp. Reinstall WhatsApp. It should work then.
    ifkdui93 likes this.
  18. ifkdui93
    It eventually uploaded after an hour and draining about 10% battery. But I can't transfer my WhatsApp folder to pc because it transfers less than half data what is there in the folder, half of the videos and images will be missing. So the only option to backup is Google drive if I don't want to lose my data.
  19. Adi_2019
    Transfers half data? Never happened to me and can't think of a reason why would it. I copied media and database folder only.
  20. ifkdui93
    Adi_2019 likes this.
