56
OxygenOS 11.0.4.1 for the OnePlus 7T Pro and OnePlus 7T
  1. zer0se7en
    Ice Cream Sandwich Nov 26, 2021
    zer0se7en , via OnePlus Community App , Nov 26, 2021 :
    I do think it does. Almost same as you, I rarely encounter problems. I also always do a full flash update even before when it was still unrooted. I guess people having problems should also try flashing the full update. Nothing will be wiped anyway. So it's worth a try.
  2. ilham_qrsh
    Gingerbread Nov 26, 2021
    ilham_qrsh , via OnePlus 7T , Nov 26, 2021 :
    I don't think it's cosmetic bug. It's impacting my 7T. Everytime phone shut down then on restart it didn't accept the screenlock. Then I have to factory reset the phone. After reset it didn't accept the last screen lock for Google backup to restore. I lost my back up twice. Any suggestions or update would be appreciated.
  3. Edward_
    Edward_ , Nov 26, 2021 :
    I looked at the pixels. They are a downgrade in many respects, despite costing £849 here in England.
    They absolute bricks for starters - 210g and 9mm thick. And they don't have face unlock either.
    I'm sure the camera is awesome, but I'm not a big photographer and the OP7T is just fine for my needs.
    RevidFfum and JanLuck.Pincard like this.
  4. JanLuck.Pincard
    Jelly Bean Nov 26, 2021
    JanLuck.Pincard , via OnePlus 7T , Nov 26, 2021 :
    I only see the misallingment of the google Item in aettings.
    I do not experience the other problems you describe.
    Thus my answer.
    ilham_qrsh and accuphase like this.
  5. Totsquest
    Honeycomb Nov 26, 2021
    Totsquest , via OnePlus 7T Pro , Nov 26, 2021 :
    The only reason I suggest the pixel was software. I have much the same needs as yourself but I use my phone for stadia when not home.
    I upgrade myself in march/May with my network and have always had snapdragon top tier so was stocked when they had oneplus phones last time because of oxygen. I have been in to my network to play with a 9 pro and test the software. I wasn't disappointed quite attractively set out.
    Have you tested color os...?
    devourerOfBits80 likes this.
  6. AndroidManiac
    AndroidManiac , Nov 26, 2021 :
    I've been flashing recoveries and ROMs for about 10 years now.
    Having said that... I do understand the bugs that can be and will be introduced while updating ROM versions and that happens from time to time. I'd also admit that sometimes I don't always follow step by step instructions which have caused me various problems a long the way.
    I'd also admit that I'm mostly a dirty flasher also and I'm also well aware of the issues that may and can cause.
    I got my OnePlus 7T at its release and only have clean installed OOS ROM only once and that was too try and correct the first problem of widevine L3. That did indeed correct the widevine back to L1 until I unlocked the bootloader. So I lived with L3 until the specific update corrected the issue as advertised.
    Just my 2 cents worth of experiences with my OnePlus 7T. Always dirty flashed every stable update released with the full update package and only experienced two issues of which one officially resolved and awaiting the latest resolution for the other. I'm grateful mine is still operating like it's new and for that I'm grateful. Thanks
    edit for spelling
    Neitred likes this.
  7. Mohan Reddy Y V M , via OnePlus 7T Glacier Blue , Nov 27, 2021 :
    True to some extent
  8. VShubham410
    Gingerbread Nov 27, 2021
  9. avinash_verma
  10. Nishant Daniel
  11. Arvindpattir
    Donut Nov 27, 2021
  12. Boomer112
    Eclair Nov 27, 2021
    Boomer112 , via OnePlus 7T , Nov 27, 2021 :
    I've nearly always had focus issues, especially with the wide angle camera. Otherwise the focus works fine 95% of the times.
  13. Aayatkhan
    Donut Nov 27, 2021
  14. F_Vipul_Singh_hbRN
    Donut Nov 27, 2021
    F_Vipul_Singh_hbRN , Nov 27, 2021 :
    With this update, I am happy to report that on my device, the UI stutter issue has reduced significantly. Now, the stutter happens (on an average) once in 3 days or so, and goes away on its own in about a minute. Earlier, I had to cycle through refresh rate settings to remove the lag.
    Hope that OnePlus licks the problem completely in UnifiedOS (EtihadOS? 😁)
  15. RevidFfum
  16. Rasith_Kanchana
    Cupcake Nov 27, 2021
  17. Arvindpattir
    Donut Nov 27, 2021
  18. L1638013409480
    JOSONEN likes this.
  19. Dikran666
    Dikran666 , Nov 27, 2021 :
    I've got approximately 1 week left on my OnePlus 7T, then my Brand New OnePlus 9 Pro, 256GB/12GB in Stellar Black arrives! 😎👌 Attach1827_20211127_164907.jpg
    Kerkdriel_Online and Totsquest like this.
  20. PLGdu94, Zafar0507, Totsquest and 5 others like this.
